20 Most Recent
Simpson WaterBlaster Commercial Gas Powered Pressure Washer 4200 PSI @ 3.5 GPM Honda GX390 Engine And 50' MONSTER Hose #WB4200 Questions & Answers
How do I remove wheel?
You first have to pry the cap off the wheel with a screwdriver then under the cap there should be either a pin which you pry off or a nut which you loosen.
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual:
http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf
No oil is required for the pump.
10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily).
The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine).
When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
