20 Most Recent
Electric Kranzle Professional 1600 PSI Pressure Washer Questions & Answers
My kranzle pressure washer does not make any
Could be just a blocked nozzle, Is the unloader vlalve on the side of the machine turned clockwise, does the pump leak from underneath,Is the water filter blocked. Please check all these thing.
What type of oil should be used to lubricate the
any antifoaming oil but alot of people use multigrade their oil goes creamy as if its full of water but it is just oil that is foam and the air in it takes forever to to come out there are a number of anti foaming oils available use one of those
How many chain link and what size is on the Mastercraft mc-2000, also it is electric so how much power output is there?
- I apologize, but I am unable to determine the specifications of the Mastercraft mc-2000 chain link as there are many different models and variations of Mastercraft chain saws with different specifications.
I suggest checking the user manual or contacting the manufacturer directly to obtain information on the specific chain link size for your model.
As for the power output, I also cannot provide a specific answer as it will depend on the specific model and its motor specifications. However, electric chain saws generally have their power output measured in amps, which can range from around 8 to 15 amps.
Black and Decker HP9048 Type 1 battery pack
if you're looking for battery packs that will fit the screwdriver, you might check on ebay and alibaba with merchants who are selling your product. It's possible that they could still be selling a generic brand of the rechargeable battery for your device as well.
Thank you.
