20 Most Recent Kirby Heritage II Vacuum Questions & Answers
Kirby Heritage II vacuum cleaner. Foot switch wiring and theory please?
Question edited for a lot more clarity and add maker. Question moved from Sewing Machines to model category. Just replace it. https://www.google.com/search?q=kirby+heritage+ii+vacuum+footswitch+replacement ...
2/22/2023 6:59:21 AM • Kirby Heritage... • Answered on Feb 22, 2023
2answers
Does anyone know how to use a kirby as a shampoo cleaner
check @ youtube, just type kirby shampoo
5/14/2018 1:39:55 PM • Kirby Heritage... • Answered on May 14, 2018
How do I replace the roller brush on a kirby Heritage II?
The brushroll is held onto that baseplate by the metal brackets on either end of it. You have to slightly bend them outward to remove the brushroll.
12/27/2017 2:02:30 PM • Kirby Heritage... • Answered on Dec 27, 2017
Kirby heritage 2 repair manual
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kirby model by clicking the link below. http://kirbywhq.powweb.com/manuals/heritage2/18F36C000B8A1B4BC17B195AFA60B506/Heritage%202%20Manual.pdf You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Kirby I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/26/2017 10:03:24 PM • Kirby Heritage... • Answered on Nov 26, 2017
I was using my Heritage 11 vacumn with the hose
Hi, the motor could be overheating. Most vacuums have a heat sensor that shuts the vac. off if there is a clog. Let it sit, feel if it's hot. If so you may have a blockage of dirt etc. Try to clear it, let it cool and tart it up. I hope this helps, if not let me know with more details and we can narrow things down Chris
8/31/2017 2:19:28 PM • Kirby Heritage... • Answered on Aug 31, 2017
How do i replace the switch?
need more info ie which model
8/24/2017 1:03:34 AM • Kirby Heritage... • Answered on Aug 24, 2017
Service manual schematics
6/29/2017 7:56:29 PM • Kirby Heritage... • Answered on Jun 29, 2017
Kirby Heritage II Replacing the Motor in the housing HELP!
this mite help
3/23/2017 4:46:47 PM • Kirby Heritage... • Answered on Mar 23, 2017
How do I change the fan on a kirby heritage
3/23/2016 4:33:05 PM • Kirby Heritage... • Answered on Mar 23, 2016
How to replace the belt on kirby heritage II model 2-HD
https://www.youtube.com/watch?v=z33PPzoGBzg Kirby Heritage II and Legend Vacuum Owner Video
11/2/2015 5:41:19 PM • Kirby Heritage... • Answered on Nov 02, 2015
While using it, started making a loud noise. Turned off. Came back wouldn't work. What's wrong?
Also when i read this its looks like the motor armature could be damaged, to test first plug out for shure the powercord. If when a collector on the armature is defect you must turn the motor a little to know if it is true and if thats so, you can test it try to lift the front cap turn a little the motor on the shaft where the belt runs on connect the hose again or what you will use operated switch ON and operate the cableplug of powercord to look when it works again then you know that the noise is the armature, the collector thats broken is a little higher in the commutator circuit and therefore it stops in the most time right on one of the 2 carbon brushes, which may be the reason that he suddenly stops working and also make noise. Other examples can i not anOther reason are the carbon brushes in which the automatic stop is addressed, but that is not associated with noise. if a belt is broken the motor runs fine only if a dust bag or hose are distconnected then that 2 security switches only are the cause thats why it not worked anymore but the chance that its fortuity is 1-1000. 25830467-lfkxcpojx51wojgzm0n2wodu-5-0.jpg
10/21/2015 12:13:38 PM • Kirby Heritage... • Answered on Oct 21, 2015
Where does the power light clip on to on the kirby legend 2 1984
The light clips into the top and mid point of that black on off switch. It is the biggest pain to see those 2 entry terminals on the back of that switch and the only way is to cut those white tie wraps that go around the light wires to the pot metal frame to get just the extra amount you will need. A good light source and a sharp pair of needle nose pliers will be needed to push the 2 light plugs into that main black switch. I used to dread that when replacing those entire switches until getting used to it. Another note that if you get the motor wires reversed when plugging them into that switch......it reverses the motor and will blow instead of suck. Hope this helps! William R!
2/2/2015 6:51:36 PM • Kirby Heritage... • Answered on Feb 02, 2015
How do you put on the attachment hose to clean sta...
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
10/20/2014 8:37:52 PM • Kirby Heritage... • Answered on Oct 20, 2014
How to change Brushes on Kirby g6
you take off the front assembly, un-clip the bottom assembly where the brushes are and there are 3 different heights of the brushes just rotate it and continue to use unless you have already used all 3 sides, I, II, III are the options make sure both sides are on the same, refit back into assembly and make sure you clip the bottom back together and them replace back on to machine
8/7/2014 8:37:32 AM • Kirby Heritage... • Answered on Aug 07, 2014
How do you remove the brush from the rug rennovator?
see utube for video showing you how
4/29/2014 10:58:14 AM • Kirby Heritage... • Answered on Apr 29, 2014
Install belt
old models have 2 star screws will need two people and two screw drivers to loosen, ( be gentle)
4/29/2014 10:57:36 AM • Kirby Heritage... • Answered on Apr 29, 2014
My Kirby won't kick into gear.
her2 not a drive kirby
4/29/2014 10:51:21 AM • Kirby Heritage... • Answered on Apr 29, 2014
My self-propelled Heritage II Kirby vacuum is no long self-propelled.
her2 was not self propelled
4/29/2014 10:50:35 AM • Kirby Heritage... • Answered on Apr 29, 2014
Do the Gsix and Ultimate G Kerby bags fit on the heritage II
yes this fits, kirby now have a universal bag to fit all models see kirby.com
4/29/2014 10:02:05 AM • Kirby Heritage... • Answered on Apr 29, 2014
Vacuums Logo
178 questions posted
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
work light not working legend 2 bulb ok
  • Vacuums
