20 Most Recent Braun Activator 8595 Electric Shaver Questions & Answers
2answers
How do you replace a
I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
4/17/2018 9:18:31 PM • Braun Activator... • Answered on Apr 17, 2018
I have the Braun 9595
DC motors usually do need to aligned to controllers however, with electric shavers they are usually sold together as a "drive unit." Now as far as your shaver goes, I could not find a replacement drive unit and what I did find showed that it was discontinued. Sorry. Braun 9595 5671 Pulsonic Parts
11/28/2017 6:00:55 PM • Braun Activator... • Answered on Nov 28, 2017
Shaver has lost charge, won't recharge on station,
here is the link to the manual and the service center http://www.braun.com/us/home.html
4/4/2017 8:32:00 AM • Braun Activator... • Answered on Apr 04, 2017
Can I repair a cleaning unit (5468) for a Braun
Does the cleaning station no longer recognize the shaver? If so, it's possible that the contacts have been bent out of position. It's a bit tricky to fix, though. You'll need to take the unit apart and then bend the contacts back into position. Alternatively, you can buy used but working examples of these cleaning stations off of eBay.
1/22/2014 6:27:37 AM • Braun Activator... • Answered on Jan 22, 2014
Shaver when turned on will not start right away.
Most likely, the batteries are about dead and need replaced. You will find compatible batteries for Braun model 8595 on shaveroutlet.com at the link below. You need two batteries.http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.htmlVideos to help with installation are found at links belowhttp://www.youtube.com/watch?v=D6jRpCnB8T4http://www.youtube.com/watch?v=2oAnLpvdYqQ
10/14/2013 3:09:27 PM • Braun Activator... • Answered on Oct 14, 2013
Clean and Renew stand for braun 8595 does not seem
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
9/9/2013 12:37:44 PM • Braun Activator... • Answered on Sep 09, 2013
2answers
Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
6/14/2013 3:20:28 PM • Braun Activator... • Answered on Jun 14, 2013
2answers
BRAUN 8595 screen indicates i should change my foil and block
there is a reset button directly underneath the LCD screen
5/23/2013 3:55:10 PM • Braun Activator... • Answered on May 23, 2013
0answers
Braun Activator 8595 Electric Shaver Logo
51 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
replace
  • Health & Beauty
