20 Most Recent
Turtle Beach Ear Force X42 Headset Questions & Answers
Why am i getting no power in x42 turtle beach earphone?
I am assuming this is not a sound issue, and an entire headset not coming on issue. Here are the steps that I would take...
1. Put in BRAND NEW BATTERIES!!! (Usually that is the culprit) ;-)
2. Unplug and then re-plug in all wires and cords to the console and the controller.
3. Check to see if the wires are connected from headset to end cords (on the one that plugs into the controller).
4. Once everything is connected and with brand new batteries, it should work, turn it on again. Remember the beep sound goes up when the turtle beaches come on, and the beep sound goes down when the turtle beaches are turned off.
Cable box lights off won't turn on
This happened to me, and here is what I did... For some odd reason all of the lights and cords were plugged in correctly, except I could not hear the game chat. This happens when your headset is UNSYNCED. Take the headset back over to the xbox/ps3 and resync them. If that does not work, unplug every cable/wire to the headset (even from the xbox/ps3) reassemble it and sync it. It should work then. I have no idea why it will suddenly unsync, but fortunately it doesn't happen that often.
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
