20 Most Recent
Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S Questions & Answers
Leaky toilet
The tank will unbolt and can be removed to replace this seal.
Better yet for about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
5/20/2014 10:06:46 PM •
Mansfield...
Answered
on May 20, 2014
Poor draining toilet checklist
1. Is the toilet plugged or partially plugged. I have removqed toothbrushes, combs, toys etc. from toilet traps so check for any obstructions.
2. Rust and scale buildup. The buildup of rust , sediment and or scale in the internal passages of a toilet can greatly affect their performance.clean the small holes under the rim with a small piece of wire. Use Limeaway or CLR to remove rust and scale. put some in the tank and flush toilet. Let sit for a while and repeat.
3. Improper venting or plugged vent. A toilet needs a properly vented drain to work correctly. Check the vent to make sure it is not plugged or in the northern climates frosted shut.
4. Mechanical issues. Is the flapper lifting high enough when flush lever is flipped. Is water at correct height in tank. If it is a pressure assist is water pressure high enough. Is pressure tank waterlogged.
These are just afew of the many things that can cause a poor flushing toilet. Hope this helps.
12/28/2013 9:45:42 PM •
Mansfield...
Answered
on Dec 28, 2013
Remove toilet tank. In toilet seat is small hole
If I understand you correctly you remove the tank and looked into the opening of the bowl where the tank attaches. There is usually a dollop of white silicone sealer. This is to plug a pssage created when the toilet was manufactured. Removing this will cause the toilet to not operate properly. If the hole is not sealed properly seal with a good grade silicone sealer. Make sure surface is dry before applying. Hope this helps.
12/28/2013 3:41:02 PM •
Mansfield...
Answered
on Dec 28, 2013
Replacing fill valves in mansfield 160 toilet
If this is the standard manfield 160 toilet I recommend replacing the fill valve with a Fluidmaster 400a. They are easy to install and adjust , and work very well.I have installed hundreds of these and have had zero problems. Hope this helps.
12/28/2013 3:34:21 PM •
Mansfield...
Answered
on Dec 28, 2013
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
7/12/2010 5:09:13 AM •
Mansfield...
Answered
on Jul 12, 2010
When flushing the toilet, there is not a lot of
It is normal for these useless new tanks to do that. Won't even flush a piece of paper. Pull off the lid and make sure the little hose is in the overflow pipe, and raise the water level as high as you can. take out all the bricks and water bottles, and bowl cleaners. Then give it a try. It might do a bit better. Hope this helps.
7/3/2010 6:13:00 PM •
Mansfield...
Answered
on Jul 03, 2010
I have a narrowboat which had a mansfield toilet
While toilets can look the same there are several variables as to whether ony particular one would fit. As far as maceator toilets go, they are a little spendy but can do the job when others can't. I sugest you continue your search by googling Saniflo and go from there. There is just no single answer for you.
5/29/2010 11:40:51 PM •
Mansfield...
Answered
on May 29, 2010
