20 Most Recent
Mansfield Plumbing Products Mansfield QUANTUMOne White Elongated SmartHeight Pressure-Assist Toilet 148 Questions & Answers
Mansfield 160 extremely difficult to make it flush
If this is the model am thinking it is, you need to replace the flapper. it goes down in open to far and gets bound.Or if you have hard water or calciaum buildup,it is making for a tighter opening. I hope this helps. :)
7/7/2009 10:33:27 PM •
Mansfield...
Answered
on Jul 07, 2009
Why wont my toilet shut off after flushing?
Sounds like your float may need to be repositioned. Try bending the rod that supports the float so the float is further down in the tank. If this doesn't work then you need to buy a replacement kit for the shut off assembly. It is all one piece and includes the float and is easy to replace.
8/17/2014 11:02:18 PM •
Mansfield...
Answered
on Aug 17, 2014
My Mansfield toilet flushes but
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
3/28/2011 6:39:44 AM •
Mansfield...
Answered
on Mar 28, 2011
It requires so much force
I am going to take a stab at this with the information you have provided. If you have replaced the flapper around the time this hard flushing deal stated happening I would say the flapper is the wrong kind for this toilet. Flappers are not one fits all some have a bigger air cavity to help with the flushing process. The larger air cavity help buy floating the flapper up after it is started that way. If you didn't change flappers then I would do so at this time making sure you install the right one.
2/11/2011 4:02:37 AM •
Mansfield...
Answered
on Feb 11, 2011
2 new toilets installed. customer
Often I change the flapper to get the toilet flapper to stay up longer, giving a longer flush....
Check for a generic flapper that wiill work with the toilets you installed...
heatman101
8/5/2010 3:51:47 AM •
Mansfield...
Answered
on Aug 05, 2010
My toilet is turning on and off periodically.
Top and bottom seals:
It is best to replace both at once to assure the new seals are pliable and come together to form a water tight seal.
Replacing only one, the old seal is probably stiff or cracked and will not seal properly.
No secrete I am aware of except clean new and level parts.
10/4/2009 8:00:33 PM •
Mansfield...
Answered
on Oct 04, 2009
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
