20 Most Recent Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Questions & Answers
Bosch KGU3102GB/54 Fridge & Freezer How do you remove panel in front of fan in Bosch KGU3102GB/54
To remove the panel in front of the fan in a Bosch KGU3102GB/54 oven, you will need to follow these steps:
  1. Disconnect the power supply to the oven.
  2. Remove the screws or clips that hold the panel in place. These may be located on the sides or bottom of the panel.
  3. Carefully lift the panel up and off of the oven.
  4. Once the panel is removed, you will have access to the fan and other components inside the oven.
It is important to use caution when removing the panel, as the oven may contain sharp edges or hot components. If you are unsure about how to remove the panel or if you encounter any difficulties, it is best to seek the assistance of a qualified appliance repair technician. They will be able to safely remove the panel and provide any necessary repairs.
1/6/2023 10:39:18 AM • Bosch Exxcel... • Answered on Jan 06, 2023
Light is on but fridge and freezer stopped working
Unplug the chord and plug it a few times
1/26/2015 7:19:24 PM • Bosch Exxcel... • Answered on Jan 26, 2015
Fridge door magnetism does not work - when closing
if it's new or recently been moved for some reason, Making a minor adjustment to the front wheels, slightly positions your Refrig. so that a rear-tilt causes gravity to allows the doors to close, assisted by the weight of food products on the door. If you've had it for some time, You might want to check and clean the metal surface area and the door gasket on the hinge-side. As a habit, cleaning door gaskets, with soap and warm dish towel, will preserve the life of the gasket and save you couple of bucks down the road.
11/7/2013 6:52:36 PM • Bosch Exxcel... • Answered on Nov 07, 2013
0answers
KGV28323GB/02
Be the first to answer 1/29/2013 3:32:45 AM • Bosch Exxcel... • Posted on Jan 29, 2013Be the first to answer
Red light stays on &
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/9/2011 2:26:43 AM • Bosch Exxcel... • Answered on Sep 09, 2011
0answers
Bosch Exxel KGV28323 fridge freezer. When
I thought the same with mine, but its supposed to, there is a switch near the thermostat, if you turn it off the light will go off when the door is shut, you are supposed to leave it on if the room the fridge is in is under 18 degrees, the heat off the dim bulb stabelises the temperature and keeps the freezer working
8/4/2011 11:47:12 PM • Bosch Exxcel... • Answered on Aug 04, 2011
2answers
There is a buildup of ice behind the lower section
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/3/2011 10:30:23 PM • Bosch Exxcel... • Answered on Aug 03, 2011
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
11/6/2010 1:28:10 PM • Bosch Exxcel... • Answered on Nov 06, 2010
My fridge makes a whistling sound after I have
We have summarised all possible problem for this case here to this linkhttp://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
9/15/2010 3:47:09 PM • Bosch Exxcel... • Answered on Sep 15, 2010
Bosch exxcel fridge freezer - freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/20/2010 9:01:48 PM • Bosch Exxcel... • Answered on Aug 20, 2010
Our Bosh refrigerator is wet
this is a defros problem ( i belive) so ck for bad heater or pluged drain. the air should be dry and inside should not be wet .. mm
8/10/2010 6:38:04 AM • Bosch Exxcel... • Answered on Aug 10, 2010
Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Logo
44 questions posted
Top Bosch Refrigerators Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Bosch Refrigerators
  • Bosch Refrigerators
Most Popular Question
bosch exxel kgv28323 fridge
  • Refrigerators
