20 Most Recent Kocaso MID-M750B MID-M750B 7-Inch Tablet Black Questions & Answers
You plug the small plug of the USB cable (OTG) into the OTG socket.
You plug the large USB plug into the charger.
Plug the charger into the wall socket.
Kocaso MID-M750B... | Answered on Jan 04, 2017
SImply use a data cable and connect from your tablet to your computer. If you have windows 7 or later it should autodetect and download the correct driver.
You may have to enable usb storage on your device, When you plug it in make sure it is on and it should prompt you.
Alternatively you can turn on usb debugging and install the Android SDK. Then use it to backup the entire tablet via adb.
Kocaso MID-M750B... | Answered on Dec 15, 2015
If it reports that it is not compatible, then the system will not allow your to download the app. There are may apps that behave like this.
Kocaso MID-M750B... | Answered on Sep 07, 2015
Be aware you need a working tablet to update. the program must be in working order and the processor must run. Once you start the upgrade, there is only a small routine running, to put the new program in the right place in the Flash memory. You don't get a second chance, if anything goes wrong, because even the routine to update can't be put in place or run.
An update is NEVER a solution for a bricked tablet.
Please check some forums what to do with your problem, but please don't brick the device with an update you can't get in place.
Kocaso MID-M750B... | Answered on Apr 19, 2015
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
Kocaso MID-M750B... | Answered on Feb 22, 2015
The manufacturer does not cover accidental damage, but we instituted a program where you can turn your tablet with a cracked screen in (as long as you are still within your warranty period. The nice thing about this is that not only are we the least expensive route when you crack your screen, but you do not have to wait for repairs. We simply send a replacement once we receive your damaged one.
Contact us at Company Contact us to setup your request.
If it is under warrantee, ask for a replacement.
Company Contact us
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
You don't, it is integral part of the tablet, which you will damage if you try to remove it.
Kocaso MID-M750B... | Answered on Feb 21, 2015
The battery is built-in, you do not need to insert it.
Check its battery. If the battery have not enough charge on hold, this fault can occur. Re-charge it full, and check. If it too do not help you, replace the battery with a new one.
Kocaso MID-M750B... | Answered on Jul 10, 2014
Some screens can be replaced; some can't/
Kocaso MID-M750B... | Answered on Jul 09, 2014
SEnd it to the manufacturer where they have productions with the proof of receipt and they'll mail you the product?
That's because you forgot your password or it's not your tablet. 3 RESET WAYS on ANDROID TABLETS REVIEW
Kocaso MID-M750B... | Answered on Apr 21, 2014
Try unlocking with your Email Account. or the Security Answer that possibly you know.
if you have a back-up of your data then i suggest you to re-install your Operating System (Most Economic Plan)
If all else fails, please visit sites like Mobile Madness, it might cost about $10-$15 to unlock.
Kocaso MID-M750B... | Answered on Mar 07, 2014
Try Restarting Your phone....(removing your battery).
otherwise it is a software problem & re-installing is the only solution.
Kocaso MID-M750B MID-M750B 7-Inch Tablet Black Logo
Popular Tags
69 questions posted
Top Kocaso Tablets & eReaders Experts
 Mike M
Mike M
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Kocaso Tablets & eReaders
Most Popular Question
pictures set up kocaso m750 android
  • Tablets & eReaders
