20 Most Recent mid Archos M729B Android Tablet Questions & Answers
my tablet android 4.0 loading how to sulution this
mid Archos M729B... | Answered on Jan 14, 2020
The reset button should be on the top of the tablet and it should be silk screend on the back of the tablet as reset
mid Archos M729B... | Answered on Feb 20, 2015
Is it going through a hub/switch. If so, try direct connect.
mid Archos M729B... | Answered on Jun 06, 2014
just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
mid Archos M729B... | Answered on Mar 01, 2014
Can you tell me where you got the upgraded rom from, and have you tried downloading the firmware from the manufacturer's website? http://www.archos.com/us/support/support_tech/updates_fwm.html
mid Archos M729B... | Answered on Dec 21, 2013
Look on the bottom where the other ports are. The reset button is the tiny hole between the HDMI and headphones jacks. Use a paper clip ti reset. Make sure you feel the click as the button is really small. Cheers Keith
mid Archos M729B... | Answered on Nov 25, 2013
Did a hard reset, but touch screen does not work. Any ideeas???
mid Archos M729B... | Answered on Nov 24, 2013
You will need to perform a factory reset.
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
There should be an option to factory reset or erase your tablet.
mid Archos M729B... | Answered on Nov 01, 2013
You have to plug the iPad into the computer that you originally connected it with. Then you have to "restore iPad to factory settings". This will of course erase all your data but at least you will have your iPad back.
mid Archos M729B... | Answered on Oct 14, 2013
A bit late but FWIW, I had this problem. I eventually just moved any data I needed to a safe place & fully reset it.
To reset, hold the power button & volume up button simultaneously. It should boot to a screen that tells you what to do next. I think they ask you to keep holding the power button for a reset. Do that & you'll see a big old 3D Android figure & a blue progress bar. Give it a minute & it should eventually load. After that I got a screen that said it was "updating" & gave me a percentage countdown. It finally booted like normal to factory settings. All of my data was gone but it now turns on/off like it should.
mid Archos M729B... | Answered on Jun 03, 2013
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, pgrex@hotmail.com, 409-782-2572, thanks if you can help.
mid Archos M729B... | Answered on May 27, 2013
mid Archos M729B Android Tablet Logo
75 questions posted
Top mid Tablets & eReaders Experts
Marvin
Marvin
Are you a mid Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • mid Tablets & eReaders
Most Popular Question
forgot pattern get in
  • Tablets & eReaders
