The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Bosch Logix with error code F43 has "a motor fault". You can reset the error code by the follow steps: 1. Turn the appliance knob to the off or reset position, 12 o'clock. 2. Turn the knob to the 6 o'clock position. 3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off When your turn it back on it should have cleared the error code Check motor connector blockCheck wiringCheck motor carbon brushesCheck tacho connectionsCheck motor
this has just happened to my Bosch, means the base pan is leaking water...I've had 4 problems with mine in the past and WILL NOT BUY BOSCH AGAIN, poor customer service too.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Do you hear the pump starts turning?
If yes : some clothing is blocking the hose to the pump.
If no: electronical failure i.g. a relais on the programmer board.
