20 Most Recent Bosch Classixx WFC 2465 Front Load Washer Questions & Answers
My bosch classixx 1200 express
Close the door and turn the dial to drain
1/11/2018 9:08:32 AM • Bosch Classixx... • Answered on Jan 11, 2018
Defrost the freezer section
unpluge it
3/1/2015 1:59:43 PM • Bosch Classixx... • Answered on Mar 01, 2015
0answers
The inlet valve is not taking in water. Fix that
To say this you need to be sure the valve is not faulty, you need to test if voltage is present at the valve and if yes fit a new valve, assuming of course that water supply is good.
11/1/2013 8:28:49 AM • Bosch Classixx... • Answered on Nov 01, 2013
Bosch wfr2460 washer not working after replacing
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter? If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
10/18/2013 1:06:18 AM • Bosch Classixx... • Answered on Oct 18, 2013
2answers
Fabric conditioner section in draw always full
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
8/6/2013 5:16:23 PM • Bosch Classixx... • Answered on Aug 06, 2013
2answers
Bosch conditioner drawer
This problem is caused by the compartment not filling up sufficiently to start the siphon action. First ensure that the drawer is clean, especially the siphon tube then, with the drawer removed, check the top of the compartment. You will find various holes that let in the water, make sure these are clean and not blocked with mould. Clean out with mould remover and wire then run a cycle with no washing or softener/detergent in the machine.
8/6/2013 2:34:29 PM • Bosch Classixx... • Answered on Aug 06, 2013
2answers
Door seal fitting
Bosch Classixx WFC 2465 Front Load Washer Doorseal fitting.This video will show you how to change a door seal on this Bosch front loader washing machine and how to get the springfixing ring back on.we have allbosch repairs in our channelPlease remember to subscribe to our YouTube channel for all appliance tutorialsa 4 THUMBS rating is appreciated for answering your FREE question.
8/5/2013 2:21:03 PM • Bosch Classixx... • Answered on Aug 05, 2013
Bosch Classixx WFC 2465 Front Load Washer Logo
122 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
inlet valve not taking in water fix
  • Washing Machines
