20 Most Recent
Bosch Classixx WFL 2462 Front Load Washer Questions & Answers
Fit a new waste pipe?
you need to lay the machine on its side
this is the oposide side from the soap drawer
then under the machine locate the pump and remove the pipe from the pump
must use a spring clip youll need a good set of plyers or a pair of gas grips etc to squeeze the clip open
then the pipe will come out from its hole easily
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Bosch WFL 2462 is out of balance during spin cycle
I would think it unlikely that the springs have failed unless they are fractured.It's more likely to be the shock absorber or absorbers. Depress the drum and watch how it settles, if it continues to 'bounce' around its the absorber(s), if it settles after one bounce then it's something else.Make sure it's levelled okregardsw
Dispenser stays in the drawer.
Please bear with me as the following I have pre-typed and I need to ensure that we are talking about the softener tray of the dispenser (?). If not the last paragraph should help identify if water IS being fed into each tray in the cycle- I've added a note in bold!
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly (pull the drawer out far enough to see in then select each part of the complete cycle in turn). It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Spinn lights flash when i progamme a wash and
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
My Bosch Maxx 1650GR/10 Washing
Your local Appliance Spares Outlet should have it.
Part Number 154740 should do the trick.
LINKS:
http://www.mytub.co.uk/product_information.php?product=397069
http://www.amazon.co.uk/SIEMENS-WASHING-MACHINE-BRUSHES-Equivalant/dp/B0019Y1EFG
Hope it helps!
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
I have a classixx 1200 WFL2463GB/12 and it keeps
I would suspect that it is the element, as if it were the motor, then it would not have done a rinse cycle.
Disconnect the element and try it again, if it does not blow, then this proves it is the element.
