20 Most Recent Bosch Exxcel WFX 2467 Front Load Washer Questions & Answers
0answers
2answers
I don't have a User Manual for our Bosch Exxcel 7
I think you press and hold for ten secs to clear its a childlock
8/24/2013 8:41:57 AM • Bosch Exxcel WFX... • Answered on Aug 24, 2013
How do you remove the
How do you remove the unlock on Exxcel 7 VarioPerfect washing machine?
12/6/2011 11:30:18 PM • Bosch Exxcel WFX... • Answered on Dec 06, 2011
Going through full wash as
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/28/2011 12:52:42 PM • Bosch Exxcel WFX... • Answered on Aug 28, 2011
Machine is displaying F17 have
Hi.
F17 means that there is poor or no water inlet detected.
From user manual: F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter (see page 10 of manual). Also check water pressure is not too low.
If that does not fix the problem, then inlet valve, pressure from the house and water pressure switch must be tested. The defective part must be replaced.
Regards.
Ginko
6/18/2011 2:57:30 PM • Bosch Exxcel WFX... • Answered on Jun 18, 2011
0answers
Got bosch exxcell 7 washing machine evry time i
Check your touch pad to see if you may have the pad locked out.
3/12/2011 1:05:17 PM • Bosch Exxcel WFX... • Answered on Mar 12, 2011
My boch exxel 1600washer showing
I would advise checking the function of the pump on its own. You will find how to do this near the bottom of my general guidance notes on checking filters and pump motors ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
3/3/2011 1:41:02 PM • Bosch Exxcel WFX... • Answered on Mar 03, 2011
I have F:17 flashing on my washing machine, what
Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter in pipe connector on machine. Also check water pressure is not too low. hope this helps. F17 is water problem
9/19/2010 1:07:39 PM • Bosch Exxcel WFX... • Answered on Sep 19, 2010
Bosch exxcel 1200 express fault code f04 what is
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
6/12/2010 2:56:00 PM • Bosch Exxcel WFX... • Answered on Jun 12, 2010
Error message E20
E-20 error is for drain pump /filter blockage.
Drain the pump manually.Clean it internally.The filter and drain pump are getting blocked in your machine.It needs to be cleaned.In some cases drain pump needs to be replaced if its cracked.
This will help.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
6/11/2010 9:48:10 PM • Bosch Exxcel WFX... • Answered on Jun 11, 2010
CHILD LOCK PROBLEM
hold start button for more than 5 secs will disable child lock. same again to turn back on.
1/20/2010 10:40:39 PM • Bosch Exxcel WFX... • Answered on Jan 20, 2010
Bosch Exxcel WFX 2467 Front Load Washer Logo
39 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
dont user manual our bosch exxcel 7
  • Washing Machines
