20 Most Recent
Bosch Exxcel WVT3250 Front Load Washer / Dryer Questions & Answers
I have Borsch WFX 3250
This error indicates an obstruction in the water pump.
Tilt the machine back and unscrew the plastic bung a as glen said rather
alot of water comes depending on how far you tilt the machine. doing
this just empties the water in the drum above. once you have done this
then look to see if anything is blocking the flow tunnel. also reach in
and spin the propeller about 2 1/2 inches inside the tunnel. when you
have done this and you feel the propeller is turning freely. then screw
back in the bung.assuming you have un plugged the machine in the first
place,(safety first) then plug the machine back in and turn the knob on
the front to spin if your model and press the start button. if the drain
pump is working(when you turn it on leave it a minute or two so it can
reset itself) you will hear the pump start working.
If this doesnt work, yes, you'd need to change the pump.
Hope this helps.. Good luck! :)
Hi, I have a Bosch
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine.
Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor.
pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards.
If the pump is too old or worn out then it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
Excess noice when in dryer mode
no not really its more then likely just your fan blades touching the sides just take the top off undue the heater cover plate ahd check the fan
