20 Most Recent
Bosch 24 in. SHU5305UC Built-in Dishwasher Questions & Answers
Dishwasher repair
make certain that there is water coming into the d/w if so and you are sure that the solenoid on the water valve energizes then its possible that the strainer on the water valve might be clogged if so its going to take a bit of work to remove and clean the strainer and reasemble it are you confident .
Stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Bosch dishwasher time delay problems
Bosch Dishwasher
Repair
When the display is stuck on 2H it often means the heater is
not working. If the water is not heated, the cycle will never complete. It is
possible the heating element is bad, but a more likely problem is with the
control module PC board. The solution requires some basic repair and soldering
skills plus the tools to do the job. Bosch recommends re-soldering the
connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher
Troubleshooting Tips")
free
download here
The problem is that the circuit board copper is not
heavy enough to handle the heating element current, causing the copper to heat
and melt the solder connection. A better solution is to solder a short length
of copper wire between the two pins to provide more copper and reduce the
chance of heating as shown in the attached photo.
