20 Most Recent Digital Products International Zeki 7 Questions & Answers
If you could not fix it yet, trust you me this article will surely help. They have listed not only one but 5 ways to fix google play services has stopped. I and one of my friend were able to fix the problem with the third solution in this article. 5 Ways To Fix Google Play Services Has Stopped Error On Android How To...
Digital Products... | Answered on Jan 25, 2017
you tube has a lot of how to vids, I would try there and if all else fails? Google it!
Digital Products... | Answered on Jan 12, 2015
there is more than likely a breach in the liquid crystal housing, ruptured, or cracked
Digital Products... | Answered on Nov 27, 2014
I would think that all depends on where youre located? unless you want to send it in somewhere? then Google it! you can usually same moey on total costs if you dont have to cover S & H costs
quite often the user name is the E-Mail address of the account holder, and if you have that then password recovery can usually be sent to you via E-Mail
well if youre device doesnt have a slot for the sd card, then you will need the right adaptor cord sync with another device
I'm not sure if this will help? but it could be the the software and the device are not compatible? oh yeah and make sure you have service.
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
Digital Products... | Answered on Sep 25, 2014
good then just reset it an start over kinda, remove memory sd card ,
press reset with toothpick , might have to do it with it off or on .
That is not an Apple type number. They always start with a letter A.
Tablets &... | Answered 6 hours ago
Digital Products International Zeki 7 Logo
15 questions posted
Top Digital Products International Tablets & eReaders Experts
Marvin
Marvin
Are you a Digital Products International Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Digital Products International Tablets & eReaders
Most Popular Question
tablet unfortunately google play
  • Tablets & eReaders
