20 Most Recent
Black & Decker RC550 10-Cup Rice Cooker Questions & Answers
When i plug in my
does it have reset button have you changed fuse in plug could be element gone
For the Blacl & Decker
For white rice, 2 cups of water; for brown rice 1-1/2 cups. Different kinds of rice will vary some..
I would like recipes for
What do you mean by recipes?
What works best for me is to wash the rice until the water runs clear, constantly agitating it. Then let it set for an hour undisturbed. Add water - one knuckle joint (a little over an incy) above the rice level. Plug the rice cooker in and press the start lever down. And let it do its thing.
If you have left over rice, add about one cup of water a day to keep it from drying out.
What are the rice measurements for this cooker? I
Measurements are much the same for all rice cookers. The scoop holds around 135gms of rice for one person, then fill the cooker up to the level appropriate for the number of scoops you have used.
I find washing the rice first makes better rice.
Black & Decker rice cooker not working
Check the outlet where u plug in the rice cooker. It could be that the circuit breaker has kicked off or the fuse has blown. let me know how you make out. If that isnt the problem I have additional suggestioins
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord. make sure those two are both working good. next step is to open the Rice Cooker Bottom. Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective. Which is the reason why your cooker is not turning on is due to an open in the circuitry. Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Lost rice cooking instructions
From the users guide for the 550
FOR BROWN RICE
RICE: 2 half cups
WATER: To 2 mark, plus 3/4 cup
TIME: 32 minutes
MAKES: 2 cups
RICE:4 cups
WATER: To 4 mark, plus 3/4 cup
TIME: 39 minutes
MAKES: 8 cups
Here are the rest:
6 cups
To 6 mark, plus 3/4 cup
44 minutes
13-1/2 cups
8 cups
To 8 mark, plus 3/4 cup
48 - 49 minutes
15 cups
10 cups
To 10 mark, plus 3/4 cup
51 - 52 minutes
21 cups
Here is a link to the user guide for all the instructions. http://www.blackanddeckerappliances.com/dyn/prod/user-guide/139/RC410%20RC550.pdf
B&D CTO9000 Handle Replacement
it might be best to ask for a replacement compatibility appointment from Black & Decker by calling 1 (800) 544-6986. That way they can send someone out to your hour to check where you've attempting to install the handle. Or you might be able to email them the photos for the replacement area for faster results.
Thank you.
I have a Black & Decker digital steamer Model
I have the exact same problem - still no solution - this is the only posting I could find ... anywhere! If I figure out something, I will let you know. I love the steamer, but the beeping is also driving me nuts!
