20 Most Recent
Health-O-Meter Health o Meter BFM681DQ-63 Body Fat Scale, Clear with Silver Accents Questions & Answers
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
How do I change kg to lb on my bfm681-63
Take the battries out of the back and put them back in. The unit will be off. Hold the select button for 5 seconds and you will be able to change from kg to lbs. Hope this helps.
UP TO HOW MANY POUNDS CAN BE MEASURE IN THIS SCALE
I don't know specifically for this model, but for most like this, 300 or 330lbs is typical. To test a working scale for its max capacity, let a heavier friend try it or carefully hold a weight in each hand and stand very still when its a digital scale. A gallon plastic milk container weighs about 9lbs, so one in each hand,even if filled with water will give you an extra 18 lbs of testing room. You can also let the heavier friend or other person hold the weights to help you test the upper limits.
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
