20 Most Recent One For All URC-4330 Remote Control Questions & Answers
these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
One For All... | Answered on Feb 11, 2017
Download the codes for your box here
One For All URC 4330
One For All... | Answered on Feb 01, 2017
0281,0376,0829,0222,0000,0528. Check these codes first. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
One For All... | Answered on Jan 31, 2017
Yes. It can control all type of TVs.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
One For All... | Answered on Oct 15, 2016
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
One For All... | Answered on Feb 02, 2016
One For All... | Answered on Nov 12, 2015
One For All... | Answered on Nov 05, 2015
0028,0017,0085. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
One For All... | Answered on Feb 13, 2015
go on line and input the name and model number inside under the batteries this will give you user codes
One For All... | Answered on Jan 23, 2015
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
One For All... | Answered on Dec 21, 2014
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
One For All... | Answered on Nov 15, 2014
Entire code list cannot be included by this window.
One For All... | Answered on Oct 11, 2014
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
One For All... | Answered on Aug 11, 2014
There may not be any codes available. Most digital converters use unique codes to prevent interference with TV codes.
One For All... | Answered on Jun 13, 2014
One For All URC-4330 Remote Control Logo
325 questions posted
Top One For All Televison & Video Experts
Joe Negus
Joe Negus
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
need codes fof big easy urc 4330b03 work
  • Televison & Video
