20 Most Recent Shoprider Sunrunner 4 - 4 Wheel Scooter Questions & Answers
Howtoremoveseat?
W beck you have to remove the seat by pulling it out of of the seat post and then remove the shroud or cover by pulling it straight up You will then be able to see thebatteries. Your scooter equires two 12 volt batteries probably U1 batteries Hope this helps
10/13/2015 12:26:23 AM • Shoprider... • Answered on Oct 13, 2015
Was going up a paved steeper surface and scooter stopped suddenly. had to free wheel push it home. no longer takes a charge and does not motor any more.
hi, please check the controller , there can be a fuse located to let of the wiring loom, you see a knob located where the wring looms goes into the box.. I can repair those controllers at low cost ... Regards Rob
8/12/2015 6:37:24 PM • Shoprider... • Answered on Aug 12, 2015
Hi there i have a sHOPRIDER MOBILITY SCOOTER WHICH
The battery it is dying and it dead and the core of the battery it self can't retain enough the of charge of the electricities for to the battery to move the scooter.Change to a brand new battery ur scooter should work fine.
3/8/2014 1:52:48 AM • Shoprider... • Answered on Mar 08, 2014
How to change tires
The centre comes in 2 parts,using a socket set.Use a valve tool to allow all the air out of the inner tube unless,the wheels are solid tyres.
3/4/2014 1:06:41 AM • Shoprider... • Answered on Mar 04, 2014
0answers
Hi I have a Shoprider Rocky 4. It is about 4 yrs
magnetic brake is stuck tap with hammer or replace
10/20/2013 7:59:45 PM • Shoprider... • Answered on Oct 20, 2013
0answers
How do i find the vin nuimber
Slowly find, <a href="http://www.solartech.cn/">believe in yourself</a>, always know.Please sign in:http://www.solartech.cn/
7/25/2012 8:21:01 AM • Shoprider... • Answered on Jul 25, 2012
2answers
Trip breaker,reset it but no power to anything
Probably just a fuse somewhere. Does your battery meter work? If not, there may be a fuse on the battery harness thats blown. Failing that, depending on what make of control box is fitted to your scooter, it could be a fuse within this that has blown.
11/18/2011 9:08:23 PM • Shoprider... • Answered on Nov 18, 2011
0answers
How do you get at
Remove the seat by pushing on the seat release handle and pull it up off the seat post then remove the rear shroud cover and there are the batteries undo the velco strap and remove the wires from the battery post and replace with the fresh batteries Hope this helps
6/12/2011 10:36:32 AM • Shoprider... • Answered on Jun 12, 2011
NEED KEY FOR SHOPRIDER SCOOTER
Get in contact with ROMA MEDICAL in UK Web link http://www.romamedical.co.uk/ I am sure they will help you with a key.
8/9/2010 12:12:28 PM • Shoprider... • Answered on Aug 09, 2010
I HAVE GOT SIDE TO SIDE PLAY ON MY SHOPRIDER
ok, under the front steering rod, you will see a screw type ball bearing holder,
First lubricate and then tighten it using your hand , then a plumbers wrench etc, but not too tight otherwise the steering may get stiff.
Regards
GeWiz
10/11/2009 1:46:41 PM • Shoprider... • Answered on Oct 11, 2009
Batteries discharge too fast
no, but batteries could be shot.
9/22/2009 7:17:06 PM • Shoprider... • Answered on Sep 22, 2009
Shoprider Sunrunner 4 - 4 Wheel Scooter Logo
24 questions posted
Top Shoprider Health & Beauty Experts
Rob Hill
Rob Hill
NOEL
NOEL
jws1013
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Shoprider Health & Beauty
Most Popular Question
change tires
  • Health & Beauty
