20 Most Recent
Electric Mobility Red Pilot 2410 4 Wheel Electric Power Mobility Scooter Questions & Answers
I have an ActiveCare Medical Mobility Scooter - 4
Hi Rosemary. The best way is to remove the seat by releasing the lever to turn it slightly, then lifting it straight up and off.
Next take off the battery cover, disconnect the batteries and remove them from the scooter. This will make the machine much lighter and easier to lift or push up a ramp.
Next release the steering column and fold down towards the rear. Place a piece of packaging or similar under it, so that it doesn't rub on the body panels and scuff the paint.
Good luck. Neil.
8/27/2010 11:42:22 PM •
Electric...
Answered
on Aug 27, 2010
Hello i have a kymco xl mobility scooter which has
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault There is a bad connection to the motor and the controllerIf 's it a Rhino controller normally a blue colour , The battery is completely empty. The scooter does not drive.• Recharge the battery immediately.If the scooter is left off for a few minutes, the battery may recover enoughto allow driving again for a short time. However, driving on an emptybattery may cause damage to the battery.Regardswww.gewizrepairs.co.uk
3/24/2022 8:52:42 AM •
Electric...
Answered
on Mar 24, 2022
Wigwag Throttle Control Pot FREERIDER loose
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
3/25/2019 7:44:39 AM •
Electric...
Answered
on Mar 25, 2019
