20 Most Recent
Pride Mobility Products Celebrity X 3-Wheel Scooter - Color Candy Apple Red Questions & Answers
Celebrity 3-wheel will not travel
- Fault for 3 blinks is to much charge in the battery and fault 1 blink indicated not enough charge in the batteries.
- Can you check the fuse by the battery and see if it is good. If it is blow the scooter will respond just like this.
- Also after checking remove the key and power down the unit for two full minutes and see if it stops blinking.
Regards,
Tony
My pride mobility cart over charges one battery
hi, ok sounds like one of the batteries need replacing, if the charger cannot get the required voltage level it will over charge,
Make sure the connections to the battery terminals are tight and try another charger if you can.
Regards
GeWiz.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
