20 Most Recent
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Questions & Answers
We have a 3000 ford
Go to youtube. type in 3000 ford tractor/ replace steering column bearing. step by step videos.
How to set timing on
Go to tractorbynet.com forums section, post the problem and you will get a excellent reply.
Ford 4000 hydraulic problems
First, make sure there is plenty of hydraulic oil in the reservoir
2nd, no leaks that are dumping the pressure
3rd, no blockage in tubes, located inside pump housing.
4th, make sure operating handle is engaging
try these and if nothing works let me know.
WHERE DO I ADD HYDROLUIC FLUID IN A FORD 30000 Tractor
On the floor pan next to the gear shiftier you will see a raised
BOLT, unscrew and you will find a screen filter inside, take filter out and clean with diesel fuel, replace filter. You can add the hydraulic
fluid there as well. NOTE: Purchase a owners manual on ebay they are important to have, and will more than pay themselves.
4cyl diesel Ford tractor. Ran great yesterday . Today it starts and cuts off. Any ideas?
Is the fuel flow strong at the injection pump ? If not you may have a partial blockage inside the tank, wouldn't hurt to change the fuel filters either. I had a similar problem with my 350 JD dozer
I checked the tank and found some debris covering the outlet hole,
debris removed problem fixed.
Also check all your fuel lines, if all the above is good, than start cracking each injector one at a time with the machine running
as long as it will run, you will notice a bad injector by the difference in sound , a good injector will cause rough idling l a bad one will not.
My PTO will not engage without grinding but works
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
We have a '69 ford 2000 3 cylinder gas tractor
It may be something with the carb like a float, valve, or jet problem, but don't rule out vapor lock. Make sure that the fuel lines are protected from the heat of the engine. Sometimes rerouting/shielding fuel lines can make a difference. Just a thought. Best wishes.
Ford 2000 tractor
Yes you blew the clutch. Never let a tractor coast with just the clutch engaged, the only safe way is to place the transmission in netural.
