20 Most Recent
Polaris ATV Questions & Answers
I have a 2005 Polaris 700 EFI. Recently it has
mine did the same thing & then it finaly quit running altogether...the gas gauge stoped showing in the display also. I pulled the old fuel pump out & replaced it with one out of a 97 ford areostar witch has an almost indentical pump & now the machine runs like new...and my gas gauge started showing again & I saved myself 500 bucks because the pump i used was gave to me...lol
10/31/2022 12:16:54 AM •
Polaris ATV
Answered
on Oct 31, 2022
Where is the fuse panel on a 2004 Polaris Sportsman 700 twin?
On 2002-2004 models, the fuse panel is located on the front frame member underneath the front fender cover.
The center cover under the front rack is removed to gain access to the fuse panel as well as the radiator.
I find it easier to unplug the headlights and remove the front rack for this.
10/1/2022 4:06:11 AM •
Polaris ATV
Answered
on Oct 01, 2022
Can't find where the fuse is on 2005 polaris 330 magnum
If you remove the Driver side palstic panel, there is a Black Pouch attached to the black wire conduit thatt you have to cut to see the 20 AMP fuse (be careful so taht you do not cut the red wires). I just did mine. You can buy it online on Amazon. Good luck.Ray
8/14/2022 2:11:13 PM •
Polaris ATV
Answered
on Aug 14, 2022
ATV Polaris 330 (I think trailblazer) wont shift into gears
I have one of these and it always throws my friends for a loop. You have to push the foot brake to get the bike in park or high. It should shift very easy with the brake down, if not check if the spring didn't come off of your brake pedal. I hope this helped.
8/15/2021 10:41:53 PM •
Polaris ATV
Answered
on Aug 15, 2021
