20 Most Recent
John Deere A,b,g Tractor Carburetor Float Dltx10 Questions & Answers
1972 john deere400 20 hp. koler eng.start shutoff wont stay runing /new caraberator/starter/coial/fuealpump
You need to find out if it is losing spark or fuel when it shuts off. A cheap spark tester will work for this and can be purchased at Harbor Freight or an automotive parts store. If it has spark you can use carb cleaner to spray into the carb and see if it will stay running. Also how long does it run before it shuts off and does it start right back up after it shuts off? More info may be helpful as there are many possibilities.
How do i set the float level for a jd model a
Although Nokia themselves have not released that "premium leather case" for the Lumia 1020, a third party company evidently has. We reported on it last week, revealing that the site Gadget2Us was selling various versions of the case, including brown "leather". We use quotes because it's not real leather, but rather a cloth layer that simulates the look and feel. Hey, what did you want for less than $10?
Luckily, Nokia's Simran Singh Sethi was kind enough to send us one to take a look at. How is it? Head past the break for quick video and some photos.
JS30 will start (sometimes) but
JS30 has a problem with the cutoff switch. The cable running to the lever on the handlebar develops slack over time, and can be tightened up by pulling the cable at the lever end. Manuver the pressed on end through the hole in the lever til it locks on the point where the cable enters the pressed on piece. This takes up enough slack to allow the switch to engage when the lever is pulled back.
I have a 345 that
Take the fuel line off of the carburetor and hold the line over a gas can. Crank the engine and watch for fuel to flow. Not just a dribble but but the flow should fill the fuel line and you should get about a coffee cup full in 15 or 20 seconds.
My john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
Gas/air mix is too rich
load screw is 1 1/4 turn in, idle is up to you. Try adjusting floats and or needle height. Make sure needle and seat don't need to be replaced and floats are not gummed up. If you have an 02 sensor by chance, that would be the problem.
