20 Most Recent
Activision Call of Duty: World At War for Xbox 360 Questions & Answers
Game not working on x box 360
call of duty has a history of being a console killer, if your xbox 360 version is older, your console engine might not be able to keep up with this kind of game, I had an xbox 360 b4 and same thing happened it plays on other games but wont play with call of duty. It also happened to my ps3, what I did was I updated my firmware version for both console. Now both consoles works with call of duty. Give it a try. Thanks
How do you set up Xbox live for Call Of Duty: World at War?
First of all: You don't set up Xbox Live for Call Of Duty WaW, you set it up for everything, Netflix, any games, movie rental etc.But you simply click one of the advertisements of Xbox Live on the Xbox Dashboard, and follow the steps, which are very simple ones.If you get problems with the registration, contact the Xbosx/Microsoft support team. :)
Someone hacked my score to
Your score is probably on Treyarch's servers and won't be reset, but maybe deleting your game save will reset it.
WARNING: You will loose any progress you have made in the campaign, but you'll still keep your achievements.
To delete the save, go to the SYSTEM tab all the way right on the dashboard, Choose memory, then Games, then pick Call of Duty WaW, then pick delete. Look at any of the other folders and delete anything related to CoD World at War. Hopefully this will reset your score online.
CODWAW
try going on online stores and buying it or try kijiji
I don't know how to mod on call of duty
Trust me, you don't want to mod. Not only does it void your warranty, but you will be banned. It's not a matter of "if" you get caught, it's "when." You will be permanently banned from xbox live, and you will be lucky if microsoft and activision don't press charges. So don't do it. It's just not worth it.
My kids world at war
I have heard of this happening before. You are reset to level 1 with negative XP and this stops you from playing online. Your only option is to contact Activision and possibly Microsoft.
Click here for Activision supportI have read that the companies like to blame each other for the problem. So, when you call Activision, make sure they help you or speak to a supervisor if necessary.
Regards,
G33k
My Internet connection or Wifi works perfectly
From Activision's website:
If you are having a problem connecting to an online game check the following:
- Make sure that you are playing in WiFi. This game will not work over 3G.
- Disable any firewall or security features on your router
- Set port forwarding on your router to the IP address of your iPhone/iPod Touch. This game uses ports 3074 and 3478 (UDP/TCP)
- Place your iPhone/iPod Touch into the DMZ of your router
- If your modem supports a wireless connection then try turning off the router and connect wirelessly directly to the modem. If it works regularly at this point something about your router may not be completely compatible with the specific needs of this game. Check with your router manufacturer for additional steps that may need to be done to resolve the issue you are having.
NOTE: If setting port forwarding or DMZ helps your connection issue, you may want to assign your iPhone/iPod Touch a static IP address within your home network. This can help to ensure that the configurations you made do not need to be done again.
NOTE: Many broadband internet modems are coming with routing capabilities built in. Please contact your internet service provider to determine if your internet modem has an integrated router. If it does, they should be able to assist you with the steps above for setting up your router.
My son is playing the
Zombie mode within call of duty is a game to test how far a player can go with only one chance/live. There is no saving or restarting whatsoever. There is no cheat to go around this. My only suggestion is for him to keep on practicing, and eventually he will continue to reach a higher level. There is also a variety of zombie maps that can be bought.
I go hacked and it
the cheat disables your XP and if cheat is activated online pay will be disabled as well. It only works on campaign mode only.
