20 Most Recent
Buck FIFA 09 for Xbox 360 Questions & Answers
Cant connect to ea servers
to play on EA servers you need to create an account with EA first. first of all. if you have an ea account then try to log off of it, then sign on again.
if you don;'t then try to create an EA account first
I have the same problem
EA severs not there means EA may have pulled them off 4 a bit to fix them or they are having problems so dont worry mate just try every so often. i would say that u wont need to wait long.
Not connecting to the ea server
this seems like ea dont have enough power for the amount of people willing to play their games. it seems a lot of ea games are not connecting so i would say that ea need to upgrade themselves its not you as many people have the same problem
When i try to play
There is a problem with either the DVD drive or the laser in your XBox 360. This happens with time on laser driven game systems or electronics.
Your 360 will need repair -- if you can do it yourself, you can find parts at the following website. If you're not able to do it yourself, they also provide the service:
http://store.richspsxparts.com/xb360rese.html
Fifa 09 freezing not running fast
Geforce 7100 is a built in graphics card, so you may not be able to play this game at a high setting. Try lowering the game settings to see a improvement in speed.
Xbox not reading Fifa 10 game
Well your disc is officially garbage because it's scratched beyond repair. Don't bother trying to fix your game disc. Do what I did. Go to
sellitbroken.com and sell your game to them. They will give you good money for it.
Unable to play a game
Try cleaning the disc and check it for deep scraches. if it has deep scraches get a skip Dr (works like a champ) if this does not work. is the DVD drive and you should call a xbox 360 Repair shop.
Fifa09
this happended to me. took it to game and they put it through the scratch remover machine... works fine and for £3.99 not bad
When i put fifa 09 on xbox in the xbox it doen't
There are three possible solutions for this problem
Either
1) Your disc is dirty or damaged and unplayable
2) the disc has a manufacturing flaw in which case it can be returned to the manufacturer and if they can verify that the disc is the problem they will replace it free of charge (check the back of the manual for return details they vary from game publisher to game publisher) (this would be the EA one so ANY EA game will have this info in the back)
3) the problem resides in your Xbox, and this is a low probability. but in the case where they get you a new game and it still doesnt work call 1-800-4MY-XBOX. They will have you run some push button diagnostic codes and it will tell them if there is a problem with your system.
GL please rate this thread as useful if it was useful to you :)
Brad
