20 Most Recent
Nintendo CTA Digital WI-BBP Wii Fit Balance Board Battery Pack Questions & Answers
My wii balance board says
It may be that the batteries in the board are dying. If you ave not replaced the batteries recently, I recommend doing so. If it is the batteries, the board is trying to communicate with the Wii and can but cannot sent all the info about whoever is standing on it. It simply does not have enough juice.
Balance board says please step off me and press A
Have this problem as well, what works for me is stepping off the board, lifting it off the ground until it begins to reset and then setting it down, obviously a problem with the corner sensors sticking.
Balance board says we are
There may be something pressing on a sensor inside the balance board.
Blow compressed air into the board to try and dislodge any dust that may have got inside.
If you do not have compressed air try blowing into it.
Wii balance board bottom left sensor not working
Most likley a bad capacitor on the sensor input located on the board. Unsolder the problem sensor, measure accross each individual capacitors (3). Should measure infinity. If not remove capacitor and solder back the sensor. These are high frequency filter capacitors which is not critical to the operation of the board.
Board was submerged under water (recent storms). I
What you can do here for this problem is to do a software update on the unit if there's any update from Nintendo since the unit is still working and you just need to reset it again to make it working.
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
My Wii Balance Board will not power on even after
you must have the batteries in wrong or they are not charged. Another thing is maybe try putting in a compatible game pretty sure it will sync with out one in but if im wrong its worth a shot.
If this dont help your board probably is toast.
or try please call 1-800-255-3700 for assistance.
Communications with the wii balance board have
there is a time frame that will auto shut off to save power or sometimes in certain games like punch out this happens alot its bugs that they never fixed just step back on it ect to get it going again its a pain but nothing else to do til nintendo fixes there own issue
Im having trouble with my balance board keeps
the board is most likely defective, I have seen several boards with this problem. I believe it is related to the defect in the right rear foot sensor. try using the board check test to see if it will show the defect and replace the board.
My wii board looses conectivity when i'm doing
The sync button for that battery pack is raised slightly from the outer surface of the cover. make sure nothing is under the board that could be pushing on that button, ie high carpet could do it. if your on carpet be sure your using the feet extenders. if it still happens try setting it on a board or other solid surface. hope this helps
