20 Most Recent Lenovo IdeaTab A2107 7" 8GB Tablet Questions & Answers
When it locks up after incorrect pattern 5 times on the bottom right you can hit the button labeled "forgot pattern?"
Lenovo IdeaTab... | Answered on Feb 20, 2017
Im assuming its wireless ?
The Lenovo Thinkpad is a line of primarily business and performance laptops that have wireless capabilities offered in its standard feature set.
The Thinkpads can have issues with the wireless such as poor connection speed, undetected wireless cards and problems connecting to a wireless network.
Slow Connection
A Thinkpad that can connect to wireless networks or Internet may exhibit slowdown or performance issues when downloading or transferring files.
A few possible fixes for this problem include reconnecting to the wireless network, resetting your router or modem or moving away from any devices that could interfere with your wireless connection.
No Connection
If the Thinkpad cannot connect to the wireless network at all, it could have a software or a hardware issue.
Thinkpad laptops need the wireless receiver button switched to the "on" position in order to pick up any wireless signals.
The operating system should pick up the wireless card automatically but a driver or operating system update could fix any compatibility issues between the OS, the network card and other devices on the computer.
The Thinkpad will be unable to connect to your wireless network if you are attempting to connect to the wrong SSID, network name or are entering the wrong password.
Undetected Adapter
The incorrect installation of device drivers may lead to the wireless adapter or card being undetected by the operating system.
Lenovo's support site, in Resources, contains the specific wireless card drivers used by your Lenovo Thinkpad.
For third party PCMCIA wireless network adapters or wireless USB dongles, the manufacturer of the device should have drivers to install. It is possible that the adapter could have a hardware issue.
Most Thinkpads have the wireless cards integrated into the motherboard, so you would need a complete motherboard or laptop replacement to fix a physical problem.
http://www-307.ibm.com/pc/support/site.wss/migr-50402.htmlalso
Internet Explorer Download Problems
While most people use the Internet Explorer Web browser to connect with the computerized world, some are unable to successfully download a file, program or application with it.
There are ways to determine the cause of this problem.
Use the Disk Cleanup
The first avenue to take in determining the cause of download inability is to clean your "C:" drive with your computer's "Disk Cleanup" application.
To find it, click "Start", then follow "Programs," "Accessories" and then "System Tools."
Disk Cleanup will clean your hard drive by eliminating broken file fragments and unnecessary files. These can cause your downloads to be slow and, sometimes, broken.
Antivirus Programs
Another culprit that can prevent downloads are antivirus or antispyware applications that you have installed. Shut those down, then attempt your download again.
If the download completes, then remove the mentioned applications.
Start-Up Programs Sometimes, start-up programs can keep your download from completing.
If you are running Windows Vista, click on Windows Defender, then "Tools" and check "Software Explorer."
Then select "Start-up Programs."
If you find a program that is not necessary to run at start-up, click "Disable."
Then click "Yes" to confirm your choice.
Other Programs
Disable all other programs, then try the download again.
If your download can be completed upon the disabling of these programs, and they are nonessential to your Internet sessions, then keep them disabled via your task manager.
Explorer Add-Ons
Open your "Start" menu, then point your mouse on "Programs."
From the pop-up menu, mouse over "Accessories" and then "System Tools."
Then click on "Internet Explorer (No Add-Ons)."
If you are not running any add-ons (a page will appear informing you), then this is not an issue with downloading.
Considerations
If none of these allow you to download efficiently, consider trying a new browser such as "Firefox" or "Opera."
Also, consider the possibility that the page from which you are downloading may have an internal error that can cause the download to be aborted.
General Download Problems
http://inetexplorer.mvps.org/answers/40.html
Lenovo IdeaTab... | Answered on May 08, 2015
Should diagnose charger and battery. If you don't have the electronic tester, should seek professional assistance
Lenovo IdeaTab... | Answered on May 07, 2015
Check your charger. If you don't have an electronic tester, you should ask for service. Also might diagnose battery issue
Try a factory reset, if can. Else you should take it to service
https://www.youtube.com/watch?v=0uvU-bscH2g
learn arabic or go on youtube and get a video solution of how it wont be hard
Lenovo IdeaTab... | Answered on Sep 23, 2013
plug into a computer and if it still dont work then send it off
how unlock patern of my lenova idea tab?
Lenovo IdeaTab... | Answered on Jul 29, 2013
remove the small part of the back cover and press the reset button near the sim card slot.
Lenovo IdeaTab... | Answered on Feb 19, 2013
you have to install standard android developpement tools (SDK,ADT) ad eclipse (Juno latest release). Download SDK
Lenovo IdeaTab... | Answered on Feb 17, 2013
Take it to a repairman. seems the screen VGA input has an issue.
Lenovo Computers... | Answered on Jan 20, 2020
Hello Jason,
The error message that u have mentioned seems that the virtual memory(page file) is less. please increase it from
Start>>Control Panel>>All Control Panel Items>>System.
On the left hand please select the option"Advanced System Settings".
In the System Properties Page select Advanced.
Under Performance option click on Settings tab.
In Settings select Advanced tab.you will find the option Virtual Memory
click Change Uncheck "Automatically manage paging file".
Now, Select your drive and click custom size and enter the minimum and maximum size from the details available in bottom under total paging file size.
click OK and restart your PC.
Lenovo Computers... | Answered on Jan 17, 2020
Settings - Display - Uncheck Mirror Display.
Lenovo Computers... | Answered on Dec 24, 2019
ask them yet, the actual makers,
no 2 PCs on earth reset the same way (bios)
https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/flex-series/flex-3-1470
ask the maker, first.
Lenovo Computers... | Answered on Dec 17, 2019
First, I'm Not an Lenovo tech
* Contact Lenovo for support; https://www.lenovo.com/us/en/
*** Following is for information only.***
* Forum refers to a cable; https://forums.lenovo.com/t5/Android-Yoga-Series-Tablets/Yoga-tab-3-connecting-to-tv/td-p/2259037
* Cable; https://www.lenovo.com/us/en/accessories-and-monitors/cables-and-adapters/cables/CABLE-Lenovo-DisplayPort-Cable-Kit/p/0A36537?cid=us:cse:qza7ob&utm_source=CSE&utm_medium=Banner&utm_campaign=CSE__Connexity
* Customer review; https://www.youtube.com/watch?v=nYsz8_zdOAA
Aloha, ukeboy57
Lenovo Computers... | Answered on Dec 11, 2019
Lenovo IdeaTab A2107 7" 8GB Tablet Logo
16 questions posted
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
pattern many attemps tab locked hw
  • Computers & Internet
