20 Most Recent
Dmm Call of Duty: World at War Questions & Answers
Cant conect with friends
hallo i had the same problem
its not a problem with the game, its a problem with your modem or router
steps to take are
1) updade firmware on router/modem, check the manufacturers website
2)set the ps3's ip address to static
go to settings
network settings
manually set the ip address to static
(192.168.2.200 is preferrably good)
find the dns address (google your internet service perviders dns eg "virgin medis dns")
input both primary and secondary dns
find your routers ip (check the manual)
it should be 192.168.2.1, 192.168.1.100, somethign like that)
input your routers settings into your ps3.
now your ps3 has a static dns
3.input your routers ip address into your computers browser
login and get to the home page
you should find a tab named "dmz"
go onto that menu and add your ps3's ip addredss onto the dmz
and that sould be it done
if you need more help on your router check this out
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Call of duty won't load * world at war ps3
Your guys answers ****!! Do not delete the game data that is stupid and only works for a handful of people.1. Log off of your playstation account.2. Load the game ( it should now load fine while not being logged onto PSN)3. When reaching the start menu do not press start!!!!4. Tap the home button and log onto your account.5. After logged on tap the button again and the game will run fine.
Call of Duty World at War - PS3
Well here you to go the answer to your problem is.....................................1. Sign out of your playstation account.2. Load game (the game will load fine without being logged in.3. Stop at the start menu do not press start when it is blinking "Press Start to Continue"4. Tap the Ps home button and log on to your account.5. After logging on hit the ps button to return to the game and hit will play fine.
How to play mys ps3
Get an android phone with 4G network and create a hotspot through your phone.
Error occured during loading operation
Hello jesus_its_sp
This error means that the PS3 is unable to read the disc.
Does this error occur with other games? Has this game worked before?
The first thing you should try is cleaning the disc. Do this using a clean, dry cloth. Start from the centre of the disc and clean outwards.
Check for scratches. If the disc is damaged, you´ll need to purchase another disc.
If the problem persists, you may have a hardware problem.
Hope this helps. Good luck
ajblaj
My kidere playing Call of Duty world at war and
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Play online ps3 in hotel free wireless Internet n won't connect
I'm staying in a hotel and have free wi-fi and wired internet but I can
not seem to get online. During the connection test the "obtain IP
address" step is successful, however the next step "internet
connection" fails. This is an unsecured network and does not require
any wpa keys , and I don't think it requires an SSID. I had no trouble
connecting my laptop.
http://www.newyork-hotels.us
I cant find out
if you restored your system and it wiped out your downloaded content just set up your system so that you can access you psn account. once that is done you just need to go to your download list and re-download the items you want. starting from the main screen of your ps3 the xmb go to....
playstation network>account management>transaction management>download list.... in there you'll see all and every thing you ever downloaded on your psn account.
I cant play my game system do to an error number 8001050F
You cannot fix this yourself - however do not worry as there is a widespread issue
occurring right across the board at this very moment with the
PSN Network. Some PS3 Fat consoles are not
synchronising properly due to an internal clock error and this is causing this error to display.
Sony are aware of the problem and say they will have it resolved within 24 hours.
For a full breakdown on the issues involved please view this
FixYa Tip.
If the solution helps, please leave a vote for it. Many thanks.
My ps3 wont register my COD WAW game it keeps
hi its not a problem your end sony are having some problems with their
network just give them time to sort it out and then you should have no
problems click on the link below for more details
CLICK HERE
this problem affects ps2 ps3 psp and the problem is world wide
this problem will be sorted as soon as possible you could try
contacting sony direct to find out how long the downtime is going to be
please dont change ant settings on your console as the problem is with
them and not your console.
give them time this will be sorted out soon
