20 Most Recent
Nintendo Fifa 09 for Wii Questions & Answers
How to play fifa 09 with two or more players
Dear mcgonagle
[i think you're a fann of harry potter!]
THIS IS MY SOLUTION
IT MAY OR MAY NOT WORK
please confirm whether you have two or more remotes. If no t,hen buy. You can get remotes from the respective dealer from whom you bought your Wii from. If you already have two remotes then press the home button in your remote and go to Wii remote settings. After going there you will find an option called "reconnect". Reconnect allows you to disconnect and reconnect your remotes. For reconnecting press 1 and 2 simontaneously in your remotes one by one. Then if your remote is in good connection it will show the charge and player number of your remote. If it doesn't show then you must change the battery or the remotes themselves.
THIS SOLUTION IS NOT GIVEN BY AN EXPERT OR BY A MEMBER OF fixya.com.
Thanking you,
Yours faithfully
Anonymousman
Why fifa 09 run slow when play game
If the disc is scratched that's most likely the reason. If that's the case, then clean it off with something soft and try that. If that's not it, try restarting the console.....can't think of anything else....hope I helped some.
Opposite controls
Had a very similar problem recently. I bought a new controller and that solved the problem. 2 of my controllers have ended up useless playing fifa, although pointing at the wii menu is now problem. Its a strange one but the new wiimote works perfect
I put the game fifa 09 in on my wii and when it
it is possible you have a bad disc/scratched disc or you have a bad laser to read the disc. are you able to play other games on it and is the disc scratched? every disc has a boot up menu it has to go through and if the disc is scratched in the area of the boot mapping then it wont load. thus giving you an error.
How to edit a player
Hi. To edit your player you go to the main menu and then settings.then
you go on to team management and pick a player by pressing (a). Then
keep the button (c) pressed for 5 seconds and a editing chart will come
up and you can make everything 99.
KUTPROBLEM
cheat hack and unlock wii without modchip within 5 minutes and back up all wii games dvd homebrew and more
http://unlockwii.co.cc
How do i burn on CD fifa 09 wii?
It is not possible to burn that to a CD.
The Wii checks to see if you are using a burned copy and will not load it.
You must get a copy that is burned from the factory.
Transfersa
There should be a big SEARCH button on the Transfer Market. You can't miss it.
