20 Most Recent Washburn D10sbc Acoustic Guitar Questions & Answers
Often, the flashing green light indicates that the tuner is NOT receiving a signal and is a warning that the tuner is turned on.
First thing is to check if you have normal output from the guitar from the pickup. If the output is normal, there MAY be a failure in the tuner.
ALSO, just because a battery is new doesn't mean the battery isn't depleted... either try another from a different batch or use a voltmeter to check it. I have seen people chasing their tails due to a brand new bad battery.
When you select the tuner does the audio OUT of the guitar cut off as it is supposed to?
Washburn D10sbc... | Answered on Aug 18, 2018
In my market, these go for about $100 in good used shape.
Washburn D10sbc... | Answered on Nov 10, 2015
Postings on eBay for Washburn acoustic guitars range from $150 to $300, with occasional postings as high as $450 that I saw.
Washburn D10sbc... | Answered on Nov 09, 2015
These would be pickup specific. I would suggest either contacting :
1) The shop where you purchased it
2) Washburn spares
3) Spares department of the pickup manufacturer if the makers name is shown.
Washburn D10sbc... | Answered on Mar 08, 2013
There is no general answer to your question. An F chord usually has F,C, and A in it... If the music calls for that then either you use that or you are improvising, while somebody else in an accompaning instrument plays the chord.
Washburn D10sbc... | Answered on Aug 22, 2010
Search on YouTube.com There are some good videos of exactly how to do it!
Washburn D10sbc... | Answered on Jun 05, 2010
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Washburn D10sbc... | Answered on Apr 24, 2010
Here is a site I highly recommend:http://www.stewmac.com/freeinfo.html
Washburn D10sbc... | Answered on Mar 27, 2010
Almost any guitar store would have this and any Luthier would likely have a replacement.
Washburn is a name brand so it should be easy to find the replacement.
Washburn D10sbc... | Answered on Feb 03, 2010
Search for a like item on eBay in both live and completed auctions to find the value.
One site says about $330
I don't think this is a valid question for this site.
Washburn D10sbc... | Answered on Jan 26, 2010
Actually you can do this by adding shims under the saddle to raise the action. Then use the truss rod to make the action uniform if necessary. I try to avoid making adjustments to the neck because it could lead to undesirable perminent alteration to the neck. If you do make adjustments to the truss rod you should tune the guitar to pitch and let it sit left alone overnight to allow the wood time to adjust to the new adjustments.
Here is a link to an article on Adjusting action on an Acoustic Guitar.
Washburn D10sbc... | Answered on Jan 24, 2010
Here is a PDF Document on the system.
Washburn WT-92 Preamp
Washburn D10sbc... | Answered on Jan 20, 2010
the standard tuning is e a d g b e .go to www.fretjam.com/online-guitar-tuner.html. they have about everything you need on tuning and alternate tunings.
Washburn D10sbc... | Answered on Dec 30, 2009
Washburn D10sbc Acoustic Guitar Logo
Popular Tags
33 questions posted
Top Washburn Music Experts
Michial Gueffroy
David Gust
Bruce Showalter
Are you a Washburn Music Expert? Answer questions, earn points and help others
View Most Popular
Washburn Music
  • Washburn Music
Most Popular Question
35 year old guitar curious know approx
  • Music
