20 Most Recent Fender Squier Std Strat Mn Car Questions & Answers
se3veral things have to be ruled out, start with the cord that your using to your amp, is it good? next is the volume on both the guitar and amp also good, the last thing that should be wrong is the pickup itself unless a wire is broken off of it, you can usally check this from somewhere on the back of the guitar, if all the wires are good, check the two volume controls and on the back of the amp check the wires going to the speaker.
Fender Squier... | Answered on Mar 03, 2015
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Fender Squier... | Answered on Feb 02, 2015
mn= Mexico re =reissue
Fender Squier... | Answered on Aug 27, 2014
Craigslist or eBay...both tremendous outlets for guitars.
Fender Squier... | Answered on Mar 10, 2014
Guitar center for Cheap Used..I believe I got a new fender stratus (spelled wrong)amp for 199.99 or something
Fender Squier... | Answered on Feb 04, 2014
I just wired my own build with a diagram from the "Seymour Duncan" website. He has every configuration listed and the one for your "standard" is Identical to your intrument with the exception of the country of origin of the compnents.
Fender Squier... | Answered on Oct 25, 2013
Try this site:
http://www.guitarelectronics.com/c=zdF46LQWEcjUliMu3HRfT8hg9/category/wiring_resources_guitar_wiring_diagrams/
Find configuration of controls etc. that matches your unit.
Fender Squier... | Answered on Feb 05, 2011
Go to YouTube and search: "fender tremolo setup"
There are MANY videos about setting up the trem and the springs.
Fender Squier... | Answered on Jan 08, 2011
You should have NO fret noise if the neck is properly adjusted for string height. If you are getting fret buzz take it into a gutar shop for adjustment.
Google "fret buzz"
Fender Squier... | Answered on Jul 28, 2010
Here is a link to the instructions you need:http://www.fender.com/support/stratocaster.php Pay particular attention to Intonation Roughing It Out section. Hope this helps.
Fender Squier... | Answered on Jul 13, 2010
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
Fender Squier... | Answered on Dec 10, 2009
Maybe.....or thee is a screw or allen screw on the side of thr knob that hlds it to the shaft.
Fender Squier... | Answered on Nov 20, 2009
Sounds to me like you may have pulled off a wire when you were removing your tension springs. Yes, it matters. There's not really a cool mod you can do with your tensioner springs. If you ickups were floating completely free of the guitar, they woudl still make a sound. The only way to have no sound at all is if you pulled a wire from your input jack, or alternately your volume pot.
Fender Squier... | Answered on Aug 16, 2009
Have a look at www.stewmac.com. There is a good edscription of what you want to know at www.fretnotguitarrepair.com.
Fender Squier... | Answered on Apr 29, 2009
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Fender Squier... | Answered on Jan 10, 2009
I'm an engineer, not a musician. The device is a frequency meter set up to display the musical note input to it. If you pluck a C flat and it shows an A you need to tune your instrument till it shows a C flat. You will have to refer to the manual for operation and modes.
Fender Music | Answered on Dec 04, 2019
yes check the fuse . there is generally a fuse for power switch and that sounds like what your having trouble with. hope that helps you out.
Fender Music | Answered on Sep 27, 2019
Fender Squier Std Strat Mn Car Logo
Popular Tags
23 questions posted
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
View Most Popular
Fender Music
  • Fender Music
Most Popular Question
springs in back guitar gotten
  • Music
