20 Most Recent Slendertone Fortex Questions & Answers
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Slendertone... | Answered on May 14, 2019
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Slendertone... | Answered on Apr 26, 2015
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Slendertone... | Answered on Feb 09, 2015
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Slendertone... | Answered on Jan 23, 2015
Fortex Manual
Slendertone Fortex | Uploaded on Jul 23, 2013
Slendertone Fortex Logo
Popular Tags
50 questions posted
Top Slendertone Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Slendertone Exercise & Fitness
Most Popular Question
slendertone belt keeps beeping
  • Exercise & Fitness
