20 Most Recent
Horizon Fitness Tempo Fitness Treadmill 920T Questions & Answers
Having JUST bought a second hand T920 and tried it
I have a T920 treadmill and i used to use it. now i realised that the belt is getting rubbed and treads h started coming out so I loosened it and cut the treads that came out but now the belt is getting folded and I have been told by a sports shop that i need to replace the belt but the shop does not have one to sell. any dealer in India
Humming sound in dc motor
Test the input voltage motor, if there are voltage, the motor need repair or replace.2) Test the output voltage board, for input voltage motor, if there are NOT the board, is faulty, see the block diagram. God bless you
I need a key for my tempo 920t please help
I have looked all over online for you and there isn't a place that directly sells the replacement keys. However you can call Tempo Fitness directly and have them send you a key, you may need to purchase it from them, but as you are probably aware you need the key to get the machine to function, so you definitely need the key. Give Tempo a call at 1-866-99-Tempo, they are only open 8 AM to 5 PM Central Time though, so you will need to call tomorrow.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Treadmill does not move at all.
If the frame is broken the question is how much time and money do you want to spend. It depends on how much did you spend on the purchase of the unit and if their is a warranty on the frame. Are you willing to do the work or pay a servicer to disassemble the unit replace the frame and reassemble it? If the answer is no then I would suggest junking the unit.
Treadmill displaying temperature over for an mbh
The cause
of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is
not lubricate well or needs change. So,
first try to lubricate your treadmill belt with silicone oil and be sure that treadmill
deck is clean. If the problem continues you must change your treadmill belt.
Greetings
from Greece
