20 Most Recent
AviStart 5303 2-Way Security / Remote Start System Questions & Answers
Why does it start on it's own?
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
Avital 5303, uses the remote
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to us.. U get free manuals
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
My car alarm siren will not go off
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit...
Post results or additional questions
Uninstalling a remote starter/ alarm system in a
Depends on the type of remote. Most common fix 1. Take off the lower drivers side kick panel. 2. Locate the black remote box. 3. You should see a thick yellow wire coming from the steering wheel area that has been cut and then spliced to go into the remote box. This is the feed to starter relay and will have voltage when key in in start position.4. reconnect the yellow wire back together bypassing the box. 5. Find the red wire( power source) that goes to box and disconnect it.System should be bypassed
How do i set the time on the remote
Setting the clockTo set the clock press and hold F for five seconds, the transceiver will chirp twice and the hour selection willstart flashing. Immediately press Aux to advance the hour selection or star to reverse the hour selection.Once the correct hour is displayed press F again and the minute selection will start flashing. Then press Aux to advance the minute selection or Star to reverse the minute selection. Once the correct time is displayed simply stop pressing all buttons for 15 seconds and the transceiver will automatically exit the clock mode.
My theft wont stop flashing on my ford explore so it will not start
Is your theft light flashing when starting with the key or, just with remote starter. If the theft light is flashing during remote start, there is an issue with your bypass. If a key was used, Check the antenna ring around the ignition cylinder and adjust. Also, remove the key and make sure that it still starts the car at the ignition. If its a hardwired immoblizer bypass wired into the tx and rx at the transponder amp, check for power, ground and ground when running.If the theft light is flashing when starting the vehicle with the key, gather all ingition keys that you have for the vehicle and begin to cycle them ignition. Start the vehicle with the first key, remove it, immediately start the vehicle with the second, repeat. Timing is essential for this reprogramming process to work. Not more than five seconds can elapse between switching keys.
Installing aftermarket remote start on a 2007 Dodge ram 1500
Oh yes. You will need an interface for the remote starter to work. You can purchase an FLCAN or an XK09 but, these components must be programmed to function properly. You can purchase an EVO-ALL; it does not need to be programmed. The installation instructions can be downloaded at ifar.ca. The three components mentioned above will work almost necessary components in the vehicle . Hardwire the system with 5303 and then wire the interface to the vehicle through the CAN data wires.
Can anyone help me get my stereo unlock code for a 98 tahoe?
hmm that is realy a problem because this is security lock for stealing car radios.. you must have a 4 digit number on smal paper and a serial number on it alsso,but the solution is also to call the factory of the radio and thel them your serial on radio and thay will give you your 4 digit number PIN when you confirm you bought your radio leagaly
Regards,bis3946
