20 Most Recent Directed Electronics 479V Remote Gen 2 Responder Questions & Answers
Tring to reset remote for viper 479vp
Step 1. Place your key in your car's ignition and turn the key to "On" position. 2. Press and hold the "program" switch on your cars alarm. 3. Press any button on your car remote while you are holding the "Program" switch and release both buttons. 4. Press the "Program" switch on viper alarms transmitter once more and release it. Remove the key from the ignition and press a button on your Viper remote control to see if the programmers worked. There is another way if this doesn't work, just let me know. It's more complicated.
11/3/2019 6:58:40 AM • Directed... • Answered on Nov 03, 2019
Viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
9/23/2019 7:46:26 PM • Directed... • Answered on Sep 23, 2019
Viper 479v remote stopped working
May Need Default/Reset Performed On Unit
10/1/2017 1:15:16 AM • Directed... • Answered on Oct 01, 2017
I have a 2006 Chev Trailblazer with the RPN 474V/P/C starter and alarm. Everything worked fine for a few months and then the number of beeps the remote changed from 2 beeps to 4 when the locked button
Hi. I'm going to take a stab at this. You say it corrected itself after the battery was out of the remote. Now it is doing it again. I think you can rule out the console and go right to the remote. I would go down, get an exact copy of the remote. The reason I say this is because of the change in beeps, from 2 to 4. The signal is corrupt, the reason for the different beeps. There's a little circuit board in the remote, that can go bad just because of the abuse it gets. I hope this will help. If not, let me know and I'll check the dealer.
4/19/2017 12:33:05 PM • Directed... • Answered on Apr 19, 2017
My remote is not Working i press botton in dosent do nothing
the batteris are get over orelse circut has been cut out of the ic board
1/7/2015 3:31:02 PM • Directed... • Answered on Jan 07, 2015
Python same as Viper?
Hello Anthony, This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
4/19/2014 1:10:33 AM • Directed... • Answered on Apr 19, 2014
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and n
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
3/10/2014 3:27:09 PM • Directed... • Answered on Mar 10, 2014
2answers
Hi my English is not so good but i try to explain as good as i can :) I got a VIPER 690XV and my old Transmitter DEI479V was broken by falling down stairs. I try to repair it, but it is a broken - ins
unit has a power wire to the transmitter in the antenna when shorted it took out the transmitter. 75.00 part.
3/3/2014 8:46:01 PM • Directed... • Answered on Mar 03, 2014
0answers
2answers
What if you lock your car and set the alarm and
What if you used your key to unlock the door or, maybe ask the car nicely. Is there a question?
11/8/2013 12:50:21 PM • Directed... • Answered on Nov 08, 2013
Quiero saber donde encuentro los sensores de
Go to Rock Auto or dealer , auto zone , Canadian Tire , Wall Mart etc.
11/3/2013 3:19:45 AM • Directed... • Answered on Nov 03, 2013
I have an after market viper security system and my power windows quit working. The viper is also not working properly, shows truck is locked when it isnt. Are the problems related?
Even if the Viper system controlled the windows roll up or down functions, it should not affect normal operation by the switches. That depends on how well it was installed also. You should visit an authorized Viper retailer and have them take a look. It may be totally unrelated.
2/21/2013 12:45:01 PM • Directed... • Answered on Feb 21, 2013
2answers
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
9/2/2012 11:24:38 AM • Directed... • Answered on Sep 02, 2012
Directed Electronics 479V Remote  Gen 2 Responder Logo
61 questions posted
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Viper Vehicle Parts & Accessories
Most Popular Question
english not good but try explain as good
  • Vehicle Parts & Accessories
