20 Most Recent Hunter 21841 The Baseball Fan Ceiling Questions & Answers
The blades are out of balance. You need to add weight to the lighter weight blades to is turns smoothly with no wobble.
You can go to Home Depot or other home improvement store and buy a fan balancing kit for around $2. It will have instructions.
Hunter 21841 The... | Answered on Dec 24, 2010
Check this web address and you will see a wiring diagram to meet your needs:
http://www.do-it-yourself-help.com/wiring_diagram_ceilingfan.html
Good luck with your project. Please rate my answer. Thanks.
Hunter 21841 The... | Answered on Feb 03, 2009
hi there. yes. you can purchase the remote device at a home depot or lowes or online.
One part has to be wired into the fan and the remote part requires a battery.
good luck with it. if u need more assistance let me know
oh, and please rate my answer. thanks.
Direct from Hunter is the best place.
www.hunterfan.com > parts-manuals
Hunter Fan Parts & Ceiling Fan Replacement Parts - Hunter Fan
At Hunter, we strive to make fan installation, upgrades, and repairs easy. Visit us ... *Your model number is most commonly found on top of the fan motor on a Hunter tag. ... Some items like capacitors, wattage limiters, and switches cannot be ...
Hunter Dryers | Answered on Jan 24, 2020
Pull Chain on Bottom
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
Santa E70469
SwitchCo part # 01
or
KensElectronics.com part # ZE-208D-01
z
Hunter Dryers | Answered on Jan 13, 2020
This problem was posted on several sites, but this was the only one where I found both the cause of the problem and the solution. Mine is a Hunter 5 Minute Fan which came with no remote. And after about a month the two lights would blink together whenever I'd turn them on at the wall. So in case it helps for that type of fan or the same type of wiring arrangment here is what I did: POSITIVE SIDE: P1) Remove the light shade. P2) Remove the 3 screws that hold the cowel and lower the cowel. P3) Disconnect (pull apart) the black and red wire coupling. P4) Cut the coupling off of the black wire that comes up from the lights. P5) Strip off a quarter inch of jacket from that black wire. P6) Remove the wire nut that connects the black wire coming from the governor with the other black wire. P7) Re-use the wire nut to connect the black wire from step P5 with the other black wire from step P6. NEGATIVE SIDE: N1) Disconnect (pull apart) the white to white wire coupling. N2) Cut the coupling off of the white wire that comes up from the lights. N3) Strip off a quarter inch of jacket from that white wire. N4) Remove the wire nut that connects the white wire coming from the governor with three other white wires. N5) Set the governor aside (or just throw it away). N6) Re-use the wire nut to connect the white wire from step N3 with the other white wires from step N4. That's all, you're pretty much done! Turn on the power and test the light. If all is good, re-install the cowel and the light shade.
Hunter Dryers | Answered on Jan 01, 2020
Likely the capacitor pack is kaput but can be other. Tjese can be found on eBay or Amazon. Capacitors are model specific.
Be sure reverse switch is not mid position. Check for power at fan pull chain.
Hunter Dryers | Answered on Dec 14, 2019
i don't know. battery may be dead in remote or in wrong way. please check batteries. if all tests ok, consider another remote at <https://www.ebay.com/itm/Hunter-Universal-Ceiling-Fan-Remote-Black-Receiver-K5579-01-NEW-/383158875857>
Hunter Dryers | Answered on Oct 29, 2019
If remote and receiver is rated for fan load then this should be possible. Will need to replace remote and sensor units as 3rd party remote may not be compatible with the Hunter type.
Hunter Dryers | Answered on Oct 03, 2019
Can be almost impossible to determine code without sighting receiver. Do you have old transmitter as the correct dip switch settings would be on this. One "trick" you can do if there are more than one remote fans installed is to check other controllers for their codes. generally when installers set dip switches for multiple fans in homes they move the No1 switch from 0 to 1 or vice versa, then the switch position for second fan is move switch 2 as previous. You may be lucky and "jag" the position otherwise you will need to get to receiver.
Is there power at fan terminals? If not then fan controller faulty. If yes then internal wring faulty and replacement necessary as not a repairable item. Also check if active and neutral are available at fan. Also if remote check batteries in remote unit or could be faulty remote receiver
Hunter Dryers | Answered on Sep 17, 2019
I DON'T KNOW. IF FAN HAS PULL CHAINS, PLEASE CHECK TO SEE IF THEY ARE IN ON POSITION AND TRY REVERSING DIRECTIONS A FEW TIMES.
Hunter Dryers | Answered on Sep 06, 2019
Hunter 21841 The Baseball Fan Ceiling Logo
7 questions posted
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
son hunter
  • Dryers
