20 Most Recent
Fantom Vacums Lighting Canister Vacuum Questions & Answers
I need the two front
I have two for sale if you are still interested, and other parts for this vacuum. :)
Need a new power head
your best bet would be to try Ebay or something like that. These units were discontinued late 1999/early 2000 and no parts are available for it.
my best suggestion in this case is to invest what you would spend on the powerhead into a newer cannister. Some of the newer units have better filtration and suction than the lightning cannister does.
My Fantom Lightning canister vacuum won't turn on
You need to turn over and remove the case to get to the motor.When you get to the motor you will see a white wire going to the motor from the switch,it has a white cover over the wire,pull this cover back and there is a small fuse that is probably blown.You can check this with a electrical tester.If this is not blown the heat sink that is connected to the fuse may be bad.These parts can be found at Radio Shack.
Power head roller brush
go to guarantee vacuum and sewing center tell them the exact model number of the unit and the serial number and the brand tell them what parts you need need and they will be able to get them for you
Fantom falcon vac
see you instruction manual or download from www.retrevo.com or www.fitness.manualsonline.com see the diagram. God bless you
