20 Most Recent Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Questions & Answers
2answers
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
3/31/2023 1:21:56 AM • Hunter 22451 The... • Answered on Mar 31, 2023
2answers
Pull Chains Replacement
Replacements are available at Home Depot and Lowes. This is a regular 4-wire single-layer switch.
Mark the old wires, so you know which ports they go to in the switch (marked L, 1, 2, and 3) -- then remove the old wires by pressing a paper clip into the hole of each wire while pulling firmly on the wire. Then just push the wires into the new switch, into the marked holes.
I hope this helps! If you have any more questions, please feel free to ask!
4/8/2015 2:29:16 PM • Hunter 22451 The... • Answered on Apr 08, 2015
Best choice to make in changing a capacitor
mcdevito75 here, It"s best ti stick with theh factory 5 microarad capacitor. Also see if the speed of this fan picks up when the other is off, they may both be on the same home circuit.
7/27/2010 11:16:46 PM • Hunter 22451 The... • Answered on Jul 27, 2010
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
7/27/2010 5:30:45 AM • Hunter 22451 The... • Answered on Jul 27, 2010
0answers
0answers
Oiling fan
Be the first to answer 4/27/2010 11:39:34 PM • Hunter 22451 The... • Posted on Apr 27, 2010Be the first to answer
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
10/1/2009 6:37:01 PM • Hunter 22451 The... • Answered on Oct 01, 2009
Hunter model 27576 (Canada) remote dropped
hi,
up above the fan near the ceiling theres a cover or canopy that has to come off , and theyre inside there, and they have to be set the same as the remote or it wont work.
good luck
J
8/8/2008 4:32:06 AM • Hunter 22451 The... • Answered on Aug 08, 2008
Fan stops working for days
hi,
sounds like theres some sort of radio interference in your house, you can try to change the code for the fan, turn off the breaker at the fuse box then in the canopy above the fan near the ceiling is the dip switch for the fan, you have to remove that cover near the ceiling and look for a tiny set of switches and change the position of them , also in the remote you have to take the batteries out and change that code in the remote so it matches the new code you set in the canopy. if it still does it you can try to unplug all of your cordless phones and wireless routers in the house, anything that you have with an antenna and turn it off and unplug those to see if that helps the situation.
good luck
J
8/7/2008 7:35:12 AM • Hunter 22451 The... • Answered on Aug 07, 2008
0answers
Oh ****
Be the first to answer 7/20/2008 4:11:53 PM • Hunter 22451 The... • Posted on Jul 20, 2008Be the first to answer
Fan stopped working
Sorry to give you the bad news, but the fan motor is the major component of the fan and once they go bad it is costly to just repair the motor or replace it. You would actually save more money by purchasing a brand new fan rather than try and repair the motor on the old one. It could also be a fire hazard if you try and keep running the fan because they heat up rather quickly when electrical current is applied and they do not function properly. So if you have a switch that controls the motor and lights, please make sure that the one the controls the motor is off, but can still be able to use the lights.
If you would not mind please rate my help, I would appreciate it. Thanks.
7/7/2008 3:18:17 AM • Hunter 22451 The... • Answered on Jul 07, 2008
2answers
I need 1 Blade Arm for a Hunter Fan Model # 23554. Do you have one?
We don't have anything James, we are Fixya dot com not Hunter Fans. We only supply information. Here are suppliers and details for your Fan https://www.hunterfan.com/pages/parts-manuals?parts_and_manuals_shopify%5Bquery%5D=23554
Ceiling Fan Parts & Manuals
Hunter Fan https://www.hunterfan.com > pages > parts-manuals Enter the model number, and our ceiling fan ... The common parts of a ceiling fan include the motor, blades, housing, downrod, canopy, and mounting bracket. Missing: 23554 ‎' Show results with: 23554
Original Hunter Ceiling Fan Parts - Search Shopping
Bing https://www.bing.com > shop > q=Original+Hunter+Ceili... HUNTER CEILING FAN REPLACEMENT ARM/BLADE/BRACKET WHITE PART NUMBER K5403 ... Hunter Original Ceiling Fan Lower Plate Model 23554/23606/25606 Cast. eBay US. HUNTER ...
Hunter Fan Blade Arms
Amazon.com https://www.amazon.com > hunter-fan-blade-arms > k... OHLECTRIC Ceiling Fan Blade Arm Replacements in Oil Rubbed Bronze Finish 'Designed for 52 Inch Fan Blades, Effortless Installation with Included Mounting ... https://www.google.com/search?q=Blade+Arm+for+a+Hunter+Fan+23554 ..
2/8/2024 3:13:50 AM • Hunter Dryers • Answered on Feb 08, 2024
I need a manual for my Fox Hunter Rotavator CJC-1002 can anyone help?
Too old and too unknown. Pictures https://www.google.com/search?q=Fox+Hunter+Rotavator+CJC-1002 If there was one online, this would find it. https://www.google.com/search?q=Fox+Hunter+CJC-1002+manual This is the model line and they make chipper shredder with a similar model number and despite the western sounding company name of 'Fox Hunter', they are made in China. You could contact them direct. Zhejiang Flyriver Industry & Trade Co., Ltd. https://chijiang.b2bage.com/product-cultivators.html ..
11/26/2023 9:27:08 PM • Hunter Dryers • Answered on Nov 26, 2023
6answers
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
11/22/2023 10:57:54 AM • Hunter Dryers • Answered on Nov 22, 2023
How can I get a manual for Hunter thermostat 47300 (not 47300A)
They appear to be lumped together on the Manualzz site. My search query is modified to only show model 47300. https://www.google.com/search?q=Hunter+thermostat+%2247300%22+manual ..
11/10/2023 1:13:48 AM • Hunter Dryers • Answered on Nov 10, 2023
Manuals looking for a owners/repair manual
their are 3 models for rid do online search for info for distributors service manuals etc -----https://www.nationalpowersports.net/itemdetails?itemid=50058 ---
11/8/2023 3:21:29 PM • Hunter Dryers • Answered on Nov 08, 2023
Trying to hook up a
Did you get a solution to this? I am having the same issue
10/16/2023 9:04:31 AM • Hunter Dryers • Answered on Oct 16, 2023
What is wrong with my Hunter Fan 2227-004
Recheck all the connections and verify they are properly connected. There may be a safety switch on the body and that is not properly connected.
10/11/2023 12:42:44 PM • Hunter Dryers • Answered on Oct 11, 2023
2answers
Hunter ceilng fan remote trouble
just a shot in the dark here but those fans get real dirty real quick so have you tried cleaning the sensor cover on the fan?
9/29/2023 2:06:25 PM • Hunter Dryers • Answered on Sep 29, 2023
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
11 questions posted
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
pull chain fan difficult operate
  • Dryers
