20 Most Recent Ge Medical Systems Ge Healthcare Mac 1200 Resting Ecg System 1200 Battery Questions & Answers
How to keep the date and time set??
The memory battery on the machine has to be replaced.
9/3/2014 5:31:29 PM • Ge Medical... • Answered on Sep 03, 2014
Battery for GE MAC1200ST
Hi, Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
10/15/2013 7:13:40 PM • Ge Medical... • Answered on Oct 15, 2013
Service manuals I work in a small hospital and we
hi, if you can provide your email id then i will sent you the service manual for Mac 1200 ecg. Its not possible to upload the service manual here . Its in pdf format. Ajin
8/20/2013 12:38:01 PM • Ge Medical... • Answered on Aug 20, 2013
How do I set the date and time on my GE Mac 15 Interpretive ECG Unit?
http://www.frankshospitalworkshop.com/equipment/documents/ecg/user_manuals/Marquette%20MAC%2015%20ECG%20-%20User%20manual.pdfPage 12-3 or 201 in Adobe Reader has info for setting up date and time
2/24/2013 12:35:51 AM • Ge Medical... • Answered on Feb 24, 2013
Paper starts then stops before printing results
most likely wrong paper or a bad optical sensor. There are actually 2 or 3 different versions of the mac 1200 all of which might need different paper. if you tell me the serial umber of your unit and the part number for the paper you are using I can tell you what is the correct paper.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
1/6/2013 10:09:06 AM • Ge Medical... • Answered on Jan 06, 2013
Mac 1200 prints extra page
what's the problem?Do you need othere medical equipment,such as x ray machine,clincial lab device and so on.We are manufacturer of the medical equipments, if you are interested in ,weclome to contact with us.Email:[email protected] Or [email protected]:www.pl999.net
6/18/2012 7:18:24 AM • Ge Medical... • Answered on Jun 18, 2012
2answers
NEED TO REPLACE LITHIUM ION BATTERY ON GE MAC 1200,
I just replaced the mother board battery myself. You can buy the battery ( A panasonic 3v) from ebay for about 4$. To replace the mother board battery I did it without the soldering Iron, as I feared damaging the circuitry. THe new battery works fine. My solution requires you to have a mac 1200 that is not being picked up alot because I just put a new battery where the old one was. The old battery is soldered in place, I broke that with plyers.
6/6/2012 9:35:53 PM • Ge Medical... • Answered on Jun 06, 2012
Itis a printing problem i see the ekg lines it
hi, If you can the QRS wave on its display for all the leads and if the machine is not prinding then the problem is with the printer side. First of all you have to check is the paper is inserted propely or not. If its ok then the motor or its driving section can becom faulty. Also there is one more chance is there the battery. If any of the cells in the battery is faulty then the machine will not get the proper voltage and fails to print. Its an 18V 1.4Ah battery. If you need the service manual for the machine then I'll sent the same. For that i need your email address. I can't upload that manual by fixya as it is in PDF format. OKOK
9/29/2011 9:06:06 AM • Ge Medical... • Answered on Sep 29, 2011
I have a 4 1/2
hi,
There is a 3V batterty inside the machine located in the main board. If the battery is faulty then the memory will not hold. You can replace the battrey by removing the back cover. Have adde d a picture. The part number will be witten on it. Take the battery to any nearest electronic sparepart shop and by a new one . When you insert the new battery remember one thing the the possitive side of the battery should be on top.
ok
9/12/2011 6:50:56 AM • Ge Medical... • Answered on Sep 12, 2011
I want to know the
http://www.berkeley-medical.com.br/imagens/produtos/30.pdf
this is the manual and has the specs inside it ..and under the power supply it is specified the specs for the main supply ..which includes the main battery ..
Power Supply
Ratings 95 to 240 VAC
Frequency 49 to 64 Hz
Battery Type NiCad, 18V, 1.3 Ah
Battery Charge Time 4 hours
8/4/2011 4:42:14 PM • Ge Medical... • Answered on Aug 04, 2011
2answers
Need to replace the 3v
  • Hello, I have just received your question and wanted to give you an update. In looking at the service manual here is the battery you are needing - 92916717 Battery 3 Volt 0.255 Amp. I am tracking down where to get one and looking at the schematic on installation instructions so please allow me a few minutes for this. I assure I am working only on this at the moment.
Regards, Tony
7/22/2011 6:15:27 AM • Ge Medical... • Answered on Jul 22, 2011
Could you please tell me
hi,
3v battery part no:92723057
18v 1.4Ah battery part no :30344270
ok
1/22/2011 8:14:40 AM • Ge Medical... • Answered on Jan 22, 2011
Need replacement parts - plastic clips that attach
They usually sell these by the pack but we have a lot in stock and I can separate them for you. I just need to know what style you have so that I can provide the right one. Send a pic if you can and I will help you with this issue.
[email protected] or 800-989-4909. www.overstockme.com
9/4/2010 1:29:18 PM • Ge Medical... • Answered on Sep 04, 2010
Need battery for mac 1200 machine
We sell it for $95.00 Medical Device Depot
2/21/2010 9:24:55 PM • Ge Medical... • Answered on Feb 21, 2010
The paper is not printing out all the way the top
the bottom off the print roller might be misaligned or worn. it could also be part of the print head is out. put electrical tape on the part that is not printing correctly and see if that improves the printing. If it does, it is the print roller. If it does not, it is the print head. Please let me know if you need any other assistance.
[email protected]. www.overstockme.com. Jeff Watson
1/1/2010 9:21:43 PM • Ge Medical... • Answered on Jan 01, 2010
How can you change the date and time?
I have the user guide which explains how to do it. I can send it to you if you wish.
1/1/2010 9:06:49 PM • Ge Medical... • Answered on Jan 01, 2010
THE DATE KEEPS CHANGING AND IT SHOOTS OUT ONE PAGE
the date is changing because the internal battery which is about the size of a quarter has gone bad. if you are handy with a screwdriver and a soldering iron you can do it your self or you can sen it to a repair company and will cost about $150. It is printing out the extra sheet of paper because you are using the wrong paper. you can contact GE for the right paper for your serial number or you can contact our company. 8009894909, ask for jeff
10/26/2009 4:08:39 PM • Ge Medical... • Answered on Oct 26, 2009
Unable to open the battery compartment on my GE Mac1200 ECG
The little tab at the right side needs to be pried up with a screw driver so that is can slide freely.
6/3/2009 1:49:51 PM • Ge Medical... • Answered on Jun 03, 2009
I'm looking for a GE Logiq 9 Service Manual, I'm
possible system needs to be setup for the alteration on power . try entering on pc the specs and name in search box. you might be pleasantly surprised with. information web site .
10/30/2018 6:56:03 PM • Ge Medical... • Answered on Oct 30, 2018
How do you turn a GE Ohmeda Tuffsat Oximeter on and off correctly?
I would check the noximeter readings on the spectroscope and see if it is within tolerance to the transistor ranges on the datameter.
1/22/2018 6:35:15 PM • Ge Medical... • Answered on Jan 22, 2018
Ge Medical Systems Ge Healthcare Mac 1200 Resting Ecg System 1200 Battery Logo
33 questions posted
Top Ge Medical Systems Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
View Most Popular
  • Ge Medical Systems Medical
Most Popular Question
service manuals work in small hospital
  • Medical
