20 Most Recent
Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Questions & Answers
Where can I get a 12V manual reset relay which requires reset after a power failure during the on setting?
Get an ordinary 12v single pole relay. Connect your 12v battery source to one side of the coil (-) and one of the contacts (+). Then connect the other side of the coil (+) to the other contact, and your output cable across the coil. Of course, nothing happens until you connect a pushbutton switch ACROSS the two open contacts. When you make that switch, you power the relay, and it stays powered when the contacts close. It's called a "seal-in" relay. When you interrupt the battery power, the relay falls out and won't pull in again until you hit the reset switch.
4/23/2017 11:29:38 PM •
Delta...
Answered
on Apr 23, 2017
Where do I find a guide rail for a Rockwell 4500 circular saw?
If I'm not mistaken, that model saw is already discontinued. I suggest you call or email Tool Parts Direct or Delta. I only have band saw machine, I'm thankful that bandsawparts.com makes aftermarket parts for all brands of band saw.
7/18/2014 7:11:56 PM •
Delta...
Answered
on Jul 18, 2014
Need Manual
I strongly suggest you visit www.bandsawmanuals.com . They offer free manuals for different band saws. If you're needing bandsaw blades, I purchase on sawblade.com . They have the quality of blade just what I wanted.
5/28/2013 4:51:40 PM •
Delta...
Answered
on May 28, 2013
How do i remove old screws from woodwork - i am
If the screw is not stripped, i.e. You correctly matched screwdriver fits in the hole and will allow you to turn the screww if sufficient force were available, then there are a few tricks. One is to simply spray some WD 40 (oil) onto the screw and let it soak in a couple hours. (Make sure the oil stain isn't visible, or touches fabric which will wick it up an into an area you don't want a stain to be on.Second, if you are simply not strong enough (i.e female) you can buy an 18V drill/screwdriver, which will give you plenty of force to back out the unstripped screw.Lastly, if the screw is stripped, you will need to buy a screw extractor set. Any woodworking store will stock these little sets. You chuck a bit into your drill and it taps its way into the stripped screw, giving you a new means to pull it out. Suggestion: when replacing the screws... use stainless steel. Expensive, but top quality and they don't rust.
10/21/2011 4:46:46 PM •
Delta...
Answered
on Oct 21, 2011
Need service and repair manual for rockwell ban
Please check the publication reprints available from
this website, in particular
this link.They are owner's manuals rather than service manuals, but include exploded parts views and lists and most required instructions.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
8/2/2011 7:22:06 PM •
Delta...
Answered
on Aug 02, 2011
