20 Most Recent
Homelite ZR10926 16 Chain Saw Questions & Answers
I have a UT10947D Homelite chainsaw that uses
check that you are using chain bar oil and not engine oil as that is the main reason for excessive oil usage
make sure that there is the small restriction at the exit point
if that is missing , then that will be your problem
I cannot locate my owners
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Switch turns off
try pulling the starting rope a little bit out before you pull start it. If this does not work replace the switch.
Homelite chain saw XL925 cord pull too hard but if
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
My Homelite ZR10926 16-Inch 33cc
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
What is the best oil:gas ratio for this chain saw?
D
olmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
• 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
• 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
My Homelite Ranger 16 inch chainsaw starts great
My 16" Ranger had the same problem. Here's how to fix it. Take off the top cover and the red side cover to acess the carburator. Take the top off the carb; there is a single screw that holds it on. Inside you will see a 10mm round indention. This is a final screen fuel filter. Mine had a layer of light brown dirt over the screen. Take a small screwdriver and carefully scrape the dirt off. You don't need to clean the carb any further or adjust the H and L settings or anything. Put it back together and it should run with no bogging. down.
