20 Most Recent
Cretors Antique Goldrush Popcorn Maker Questions & Answers
Need heating element for HMKJ8a popcorn maker
Here is the link to Cretors distributors, but they do not make a HMKJ8a model. http://www.cretors.com/dealers.asp?i=16
I do not know who makes it, and a web search did not find anything. Please double check your popper model.
Doors for Cretors T-2000
Try calling their tech support at: 773-433-7450 or Try finding a local dealer at:
Our poper is burning out light bulbs in a about a
Get either "Rough Service" Or "Appliance" bulbs. They are made heartier than regular bulbs. You can also use OUTSIDE type flood lamps. Make sure you have a cover over your bulb, incase it shatters.
Heating element
Google Creators dealer. Most likely there will be one in your area?
Spinner on a Cretors popcorn popper will not work
If when you pick up the kettle to dump it you can spin the agitator in the pan with one hand easy then it is not stuck. check to make sure the motor switch is supplying voltage to the motor. If that is ok now that you have the front panel off look inside to see if the motor is turning but the drive head which comes up thru the pedistal isnt then the motor shaft pin has sheered off. if nothing is moving at all motor needs replacement. the list on those from the factory are over 600 so make sure its bad first.
