20 Most Recent Cretors Goldrush Popcorn Maker Questions & Answers
No heat at all most commonly used is just a burned wife connection in the kettle . I find that a lot of the time. To repair it you should use high temp nickel ring terminals. Standard ones won't last l long like these do. It might be time for a while new KETTLE wire set. Find a dealer in your area . They should help you determine what to do.
Cretors Goldrush... | Answered on Aug 19, 2016
The most common reason is the THERMOSTAT is short cycling or turning off to soon. It could also be one of the elements is not working any longer if it is a kettle with more than one? You should find the small red inducator light and monitor it during a popping cycle. If it's going out early on in the cycle that indicates the thermostat has opened and not calling for heat. Depends on the model, you can adjust it or replace it. I suggest calling a Cretors dealer.
http://www.cretors.com/dealer
On the Gold r unjust like the bigger units the smaller light that comes on when you turn the kettle switching tells you the thermostat is closed and it's heating. Monitor the popping cycle and see when it goes out . A common problem would be it's shutting off to soon so it's not getting enough heat to pop in the correct amount of time. If that's the case replace it. That one is not made to be ajusted. http://www.cretors.com/dealer
Go to Cretors dealers. Com and find a dealer in your area. The are the same company now so a dealer can help you if the parts are still available.
Google a Cretors dealer in your area for parts.
Cretors Goldrush... | Answered on Aug 03, 2016
Google a Cretors dealer in your area!
If you have a local hardware store who can cut them straight that's the simplest.
The heating element needs to be checked to see if it has power and if it has burned out. To do this, you need a meter that checks voltage and resistance. To test it, locate the connections to the heating element and with the machine unplugged test the heating coil with the meter set to measure resistance. It should not be infinite. IF it is then the coil is burned out.
Cretors Goldrush... | Answered on Jun 14, 2014
Any Cretors Dealer will have a replacement thermostat for the GR-6 model. http://www.cretors.com/dealers.asp?i=16
Cretors Goldrush... | Answered on May 09, 2014
The motor for a Gold Rush 6oz popper is #2429-A. It is available from any Cretors Distributor with a service dept. I don't think you can buy Cretors parts online anywhere. http://www.cretors.com/dealers.asp?i=16
Cretors Goldrush... | Answered on Mar 27, 2014
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
Cretors Goldrush... | Answered on Nov 01, 2013
Cretors Goldrush Popcorn Maker Logo
91 questions posted
Top Cretors Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Cretors Kitchen Appliances - Others
Most Popular Question
cretors nugget popcorn maker doesn 39 t
  • Kitchen Appliances - Others
