20 Most Recent Uniden TRU8885 Digital Answering Machine Questions & Answers
2answers
My Uniden TRU8885 will no longer give a dial tone or ring when called (I tried using my cell phone). All associated handsets are similarly afflicted. Cleaning peope were here today and must have pre
The TRU8885 has a Do Not Disturb feature which will disable the ring on the base and all handsets. To toggle this off, press and hold the DND button on the base. (The key is on the lower left of the keypad, next to the * key). The answering system will turn on when the DND feature is enabled, if it wasn't previously on. However, this shouldn't disable the dial tone when you call out. I suggest that you check that the base has power. After that, you have to look for a wiring problem. The problem could be the phone, the RJ-11 cable between the base and the wall jack, a wire that is damaged in the wall, or an outside line problem. First try a new RJ-11 cable; make sure not to use a wired handset cord. After that, I like to use an old corded phone that requires no power adapter to test the line. If the test phone gets a dial tone, then the TRU8885 base has a problem. If the test phone doesn't hear a dial tone, try plugging it into another jack on the phone line if possible. If there's no dial tone (or no other jack), find the incoming service box. If there is an RJ-11 plug in the box, check for a dial tone there. If you have no dial tone at the service box or can't test the line at the box, contact your telephone company. Most companies will check the line and fix outside problems for free. If the problem is at the first jack, remove the cover plate and look for a loose wire. There are two styles of RJ-11 jacks. The screw terminal type require you to strip the wire and secure it under the correct screw. For the keystone jack type, you do not strip the wire. You use a punch-down tool (available at many hardware stores in the electrical section) to push the wire back into the correct section of the keystone. The little pins will puncture the insulation when the wire is properly inserted to make the connection. See http://www.lanshack.com/wire_phone_jack.aspx for the connection wiring connections. If you have an DSL filter inside your home, replace it if it is faulty. For any other inside wiring problem, you may want to let a professional find the wiring break in the walls. Your phone company will do this for a fee. I hope this helps. Cindy Wells (I have had dial tone issues from several different causes. A single jack's wire was left disconnected after a service upgrade. Several outages were from damaged outside wiring either from mice chewing or a contractor digging through the wire. With a DSL line, the lightning strike damaged the filter and blocked all of the signals. Recently, a fiber-optic service card failed resulting in intermittent dial tone failures. Except for the first issue which I could fix myself, the local phone company or appropriate contractors fixed the issue for free. However, I don't live in an area where the phone company is trying to stop serving some wired phone customers.)
1/7/2018 5:41:06 PM • Uniden TRU8885... • Answered on Jan 07, 2018
Phone not working after brownout
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many repair tools from china supplier , and VIP Pro Shop Team help me fix this error. maybe you can try it. they website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
10/7/2017 3:15:05 AM • Uniden TRU8885... • Answered on Oct 07, 2017
A/c adapter for uniden phone
look for an electronic shop ( JAYCAR type of shop)and ask them for the charger for the phone that meets your specifications
4/12/2017 3:28:52 AM • Uniden TRU8885... • Answered on Apr 12, 2017
8answers
Uniden PowerMax 5.8
To make the message light go away when there are no messages - remove the handset from the base and press and hold the "find handset" key for 5 seconds. Resets it!
Hooray!
12/29/2014 7:34:16 PM • Uniden TRU8885... • Answered on Dec 29, 2014
How can a uniden cordless TCX905 register with a uniden dect6.0 model # dect1580
It can't. The two phones use completely different protocols. It would be like trying to view a videotape by putting it into a DVD player.
5/18/2014 9:19:58 PM • Uniden TRU8885... • Answered on May 18, 2014
0answers
Not working
Be the first to answer 2/19/2014 3:41:13 AM • Uniden TRU8885... • Posted on Feb 19, 2014Be the first to answer
Uniden TRU8885 Digital Answering Machine Logo
211 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
get d1780 cordless phone out silent mode
  • Lands Phones
