20 Most Recent
Standard Horizon HX260S 2-Way Radio Questions & Answers
Need a battery charger for the Standard Horizon
After speaking to a technician at Standard Horizon, I was able to figure out that the charge output needed to be 12VDC and 1A. Knowing this, at Radio Shack I found an Enercell 3/4.5/6/7.5/9/12VDC AC-to-DC Power Adapter (Product 273-316) and the Adaptaplug tip "H" (Product 273-340). Be sure to insert the tip to provide a Negative Tip output. Cost was $22 for the adapter and $7 for the tip.
Broke the volume switch off my HX260S.
HI...
Yes you can fix this issue your self..
trouble shooting steps as follows
If it possible open the Radio..
then find out the contacts of Volume button..
Just solder two small wires then refix the Radio
Once you have fixed turn ON and short circuit the wires to increase the volume..
if you have any clarification let me know..
HX370S Can Not TX
there are too many posibilities to your question the best thing to do is to have it checked out by your local two-way radio service center.
Standard Horizon vhf stuck at screen message "EE-PROM initializing"
It sounds as if the radio needs to be reprogrammed. It could also be a cold solder joint causing the problem but my guess is the radio needs to be reprogrammed. If you purchased this used, it is very likely that the frequencies were removed prior to the sale. OR, the EEPROM was removed to make surre that the frequencies were removed. It's typical practice for radio shops to do this to prevent unauthorized use on radio frequencies.
Where is the taxi radio wiring taken from the battery or fuse box?
Usually from the battery, but it all depends on the installer. Most of these istalls have been poorly done by people that don't have a clue. ower should be taken directly from the battery with a fuse at the battery terminal. This will reduce electrical noise heard on the radio.
