20 Most Recent
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Questions & Answers
My grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
The base of the faucet which fastens to the top of
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
How do i replace the hose
There is never a lot of room between the wall and the sink. I found it easier to remove the faucet unscrew the hose and put the new one in place
PS don't forget to turn the water off
andrew
Drips from Grohe pull out sprayer
I would say that there is dirt under the sprayer gasket.or diverter. the gasket may be cracked. easiest solution is to go to a plumbing supplier with the sprayer and replace it.
andrew
