20 Most Recent
Remington Titanium SmartSystem R-9500 Electric Shaver Questions & Answers
I have a Remington Titanium Smart system R - 9500
It is probably just a coincidence that you are having a problem with the cleaning system after you changed the heads. Based on your description of the problem, it sounds like there is a clog in the system. Look for any blockages in the openings where the fluid goes into and out of the cleaning cup.
5/24/2017 6:55:43 PM •
Remington...
Answered
on May 24, 2017
What is the procedure for replacing the batteries
There are three screws on the back of the shaver to be removed. One is easy to see. The second is visable when you extend the trimmer. The third is hard to get to and the trimmer must be disjointed at the top to get to it. Once all three screws are removed, you can remove the back cover. There are two batteries. To remove them you will need to unsnap and remove the long metal clip and then unsolder the wires connected to the batteries. There may also be a gummy substance holding a wire to the side of one of the batteries. You will need to use a razor blade to seperate it off along the side of the battery. Once the old batteries are removed, you can solder in new batteries and ten reassemble the shaver.
You will find batteries at shaveroutlet.com. See link below. You will need to order two.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
If you are unable to do this repair yourself, shaveroutlet.com can do it for you. See link below.
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
9/27/2012 2:02:34 PM •
Remington...
Answered
on Sep 27, 2012
R9500 charger/cleaner system doesn't operate.
As far as i know they don't sell the Base-system separately. Contact the Remington customer service, they may mail you one, for a price i'm sure, and if not a chance to get your money back.
-Jord
2/28/2011 11:51:31 PM •
Remington...
Answered
on Feb 28, 2011
I have a brand new
Rather then you buying a new battery or a new charger or taking your entire shave apart wouldn't it be alot easier seeing how it is new to return it this way also it wouldn't cost you anything in replacement parts as well message me back on your decision if you choose to we can take apart your new shaver which would void any warranty as well Thanks again Rick
1/1/2011 5:34:56 PM •
Remington...
Answered
on Jan 01, 2011
My smart system razor no longer charges. Have to
I had this same problem and did some research. In the beginning I was told it HAD to be sent back to Remington for the service. As with all electronics, I end up fixing them myself. I bought the replacement batteries from electricshaverstore.com for $15.00 and now it works great. Good Luck and I hope this helps!
* Make sure you get the R9000 Series Battery Replacement.
12/14/2010 6:05:57 AM •
Remington...
Answered
on Dec 14, 2010
